Ram Mount X-Grip
Eonzhiglo_imp Offline
Threads: 7
Ram Mount X-Grip
Hey everyone!
I am planning on taking a very long trip in the spring with a friend of mine over the course of two weeks, from Austin to Nashville, then off to Utah and Northern California. I am still looking around for good saddlebag options, but one thing I knew I was definitely going to need was a phone holder! I picked up the smallest clamp that Ram Mount made and decided to see if it would work for what I needed it to...and boy oh boy did it deliver.
I don't know how many of you are phone guys out there, but I have the LG V10, which is one of the larger phones out there. I ordered a new grippy case for it as the sides of the phone are steel, I didn't know how well it would be gripped by the X-grip. I went ahead and ordered the smaller sized x-grip and I can say that without a doubt this phone is definitely able to fit in it!
I am hoping to run a 12v cig lighter out of the headlight aux power so I can use my quick charger for the phone. If anyone has any experience in this that could chime in, that would be great! I realize there is another thread already sort of explaining this, but I can't really wrap my head around what needs to be done. Also if anyone has any recommendations for saddlebags that will fit with my OEM rack, let me know! They need to be able to carry 2 weeks worth of supplies!
Anyway, here are some photos of the x-grip!
[Image: 482f29acf0632bfd4d2f8556df3586ac.jpg]
[Image: 8db9b44e5f383646c66596c52f73eea4.jpg]
[Image: e474e7c5801d79159998d637247749f6.jpg]
[Image: 21e632909706f7f17cfcdde1c2f6b6e0.jpg]
[Image: 3a5a2ba0517e147ec3cdd4a2a9bb9ccb.jpg]
[Image: 8a727b0f7eb12f125b49b0165b0327b5.jpg]
[Image: 0b23edbd2e57c6e496afa21eb08d77c5.jpg]
08-25-2016, 01:40 PM
BackOnTrack_imp Offline
Threads: 3
RE: Ram Mount X-Grip
+1 for X grip. Using it for about a year. Not only it holds the phone well, there is not a hint of extra vibration.
Sent from my SM-N9005 using Tapatalk
08-25-2016, 01:55 PM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
I'm running the Xgrip as well. It has held my phone for the last 20,000 miles without issue.
For the USB port, I'm running this one and I've been happy with it.
LOOYUAN 2 USB Motorcycle Mobile Waterproof Splashproof Power Supply Port Socket Charger https://www.amazon.com/dp/B00ZEUKJYI/ref...VxbPRP3RKN
08-25-2016, 03:56 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 143
I have an X grip too. It is great!
Eon, to use the accessory connector in the headlight shell or the one back by the battery, you pretty much have 2 options.
1. Buy the matching connector and pins (and preferably the crimping tool). Crimp wires or your cig. lighter or whatever you want to the pins, then pin the connector (that means put the pins in the connector in the proper locations).
2. The easy way for the vast majority of people: Cut the accessory connector off and connect your cig lighter or whatever you want to the wires. The green wire is ground and the other is switched +12v. This method is how most have done it. Only 2 or 3 or so of us have done #1.
The accessory connectors have voltage ONLY when the ignition is on (they are switched, in other words).
08-25-2016, 10:09 PM
  Phone or Sat Nav? What mount ? Quad lock or...... Davidjill_imp 18 1,427 07-28-2024, 08:49 AM
Last Post: SportsterDoc
   Quad lock stem mount Dunn2020_imp 5 578 06-07-2023, 12:36 AM
   Handle Grip Options Yata-Garasu_imp 24 2,035 10-26-2021, 11:28 AM
Last Post: rboe
  Help me find parts to mount highway pegs please LikeAfox_imp 23 1,911 05-24-2021, 10:03 PM
Last Post: LikeAfox_imp
  Where to mount auxiliary lights Gone in 60 42 2,840 04-20-2021, 09:17 PM
  Trip Machine red leather grip wraps treedoc_imp 20 1,481 02-09-2021, 04:02 AM
  HEATED GRIP HONDA ORIGINAL - CB1100 ex 2015 Alfgaxatico_imp 9 816 11-21-2020, 09:45 AM
Last Post: Alfgaxatico_imp
  I need Grip Recommendations cbolling_imp 11 973 11-02-2020, 04:24 AM
  Tail-light Mount eddi0_imp 5 543 08-16-2020, 11:15 AM
  Side mount plate number CB1100RS Moe_rider_imp 0 302 11-03-2019, 07:54 PM
Last Post: Moe_rider_imp
