tank protection
jtopiso_imp Offline
Threads: 13
tank protection
Hi:
I am considering putting somthinf to protect the tank from minor scratches from my "belly area".
I usually ride with leather jacket (leather covers the zipper, so there is no metal-to-tank contact), so, I am wondering:
-is it worth it?
-what is out there that doesn't look nasty on our CBs?
-has someone tried "helitape"? Does it work? does it last?
thanks!
11-21-2017, 11:16 PM
alprider Offline
Threads: 92
RE: tank protection
Search for "tankpats"....if you got already any scratchs
11-22-2017, 12:05 AM
Rocky_imp Offline
Threads: 26
RE: tank protection
I have a Mag-Knight magnetic tank pad on my CB and it stays in place.
I don't know anything about the product you mention.
This has been discussed before. Use the search feature to bring up those threads.
11-22-2017, 12:11 AM
jtopiso_imp Offline
Threads: 13
RE: tank protection
(11-22-2017, 12:11 AM)Rocky_imp Wrote: I have a Mag-Knight magnetic tank pad on my CB and it stays in place.
This is what I mean:
https://www.ebay.com/itm/3M-2-50MM-Helic...096?_ul=CL
11-22-2017, 12:28 AM
Threads: 698
Likes Given: 792
RE: tank protection
3m makes clear sheeting in rolls up to 48" wide in both sticky and static cling. If you have a local shop that makes street signs ( think stop signs or speed limit signs) they might have it. I got some of the static cling clear to protect areas of my tanks.
There is also a company in the U.S that sells the static cling in kits and one of the kits is a universal kit, but the name escapes me for now. Will try and think of it and post it.
Ok thought of it, the companys name is Tankslapper
Found their website. Looks like they have a kit for the Cb1100 dlx at least
http://thetankslapper.biz/motorcycles/honda/
11-22-2017, 12:37 AM
jedd_imp Offline
Threads: 27
RE: tank protection
FYI:
I used a 3m clear vinyl to protect the hood and front fenders of my bmw back when I first bought it new.
5 yrs later, 3m turned milky, then to yellow, and 2 yrs after that, the film hardened like cement and cracked all over. Even w/ heat applied, I cannot peel it off to restore original paint.
11-22-2017, 01:02 AM
alprider Offline
Threads: 92
RE: tank protection
(11-22-2017, 01:02 AM)jedd_imp Wrote: FYI:
For example bcos this i prefer enjoy the shining wonderful original lacquer until maybe i get realy scratchs and i want it sale just so i can still put any pads there
11-22-2017, 01:08 AM
Houtman_imp Offline
Threads: 115
RE: tank protection
For the last 10 years I have used Sniders Paint Guard bought from Aerostich.
Easy to put on with just water and no problem removing them.
You get 3 sheets and cut the size you want , I just used it in the "belt " area on the tank .
11-22-2017, 01:11 AM
Threads: 698
Likes Given: 792
RE: tank protection
I've had it on the tank of my ST1300 for 10 years now, and on the tank of my CB for 3.
11-22-2017, 01:12 AM
Houtman_imp Offline
Threads: 115
RE: tank protection
If you do use the Sniders Paint Guard make certain that you do not cut sharp corners on the film.
Round the corners and it will stay on MUCH better as it will not lift so easily.
11-22-2017, 05:29 AM
  Fuel tank protection. olafurarason_imp 4 585 04-11-2023, 08:20 AM
Last Post: curated_imp
  WIND PROTECTION CB 1100 ex 2015 - yes o no ? Alfgaxatico_imp 51 2,956 10-22-2021, 11:52 AM
  NEW PROTECTION AT GOOD PRICE 110 € Alfgaxatico_imp 0 234 12-03-2020, 06:18 AM
Last Post: Alfgaxatico_imp
  CB1300 Aluminum three-point type of security rod, fitted 2014CB1100 Good protection jp4141432_imp 2 477 09-26-2016, 08:56 PM
Last Post: jp4141432_imp
  paint protection sundslash2_imp 4 422 09-15-2016, 12:44 PM
Last Post: sundslash2_imp
  Removed tank stickers, installed clear tank protector ryanschillinger_imp 6 627 07-01-2016, 12:09 AM
Last Post: Guth_imp
  Tip-Over protection '14 DLX Jeephoto_imp 6 626 12-28-2014, 04:58 AM
Last Post: Rocky_imp
  Protection oldgoat01_imp 19 1,326 01-02-2014, 01:07 PM
Last Post: soggybottom_imp
  3M Paint defender spray protection- DIY wildezt_imp 19 1,307 07-01-2013, 02:53 PM
Last Post: rjk555_imp
  Tank Paint Protection HondaJon_imp 3 340 06-22-2013, 10:43 AM
Last Post: Bbref36_imp
