here's a tire option for you
jimgl3_imp Offline
Threads: 27
I'm actually thinking of going with a 130 next time out. anyone else done that ?
04-14-2018, 10:37 PM
peterbaron Online
Likes Given: 996
RE: here's a tire option for you
(04-14-2018, 10:37 PM)jimgl3_imp Wrote: I'm actually thinking of going with a 130 next time out. anyone else done that ?
F or R ?
pb
04-14-2018, 11:01 PM
jimgl3_imp Offline
Threads: 27
oh, sorry... rear. 130/80 is a bit taller than 140/70 and will lower the rpm's a bit, which is appealing to me.
04-16-2018, 11:46 AM
peterbaron Online
Likes Given: 996
(04-16-2018, 11:46 AM)jimgl3_imp Wrote: oh, sorry... rear. 130/80 is a bit taller than 140/70 and will lower the rpm's a bit, which is appealing to me.
For general info, take a look at the tire size calculator...think it should not exceed + - 3%
http://www.tire-size-calculator.info/
How about 160 in rear ?, calculate properly prior making tire size decision.
Good luck,
pb
04-17-2018, 08:33 AM
jimgl3_imp Offline
Threads: 27
yeah, the 130 is 1.8, which does not exceed 3. and looking at your calculator, the two tires are hardly noticeably different, whereas the 160 you all like so much is noticeably wider. 150/70 is as wide as I would go on this bike. but I don't like the 150 option, as it is shorter, which is the last thing I want. I want lower rpm's not higher.
04-17-2018, 10:09 AM
peterbaron Online
Likes Given: 996
(04-17-2018, 10:09 AM)jimgl3_imp Wrote: yeah, the 130 is 1.8, which does not exceed 3. and looking at your calculator, the two tires are hardly noticeably different, whereas the 160 you all like so much is noticeably wider. 150/70 is as wide as I would go on this bike. but I don't like the 150 option, as it is shorter, which is the last thing I want. I want lower rpm's not higher.
Thumbs Up
pb
04-17-2018, 10:37 AM
  11-16 MY rear shock option - Europe/UK Tev62 0 210 02-13-2023, 05:29 AM
  Turn signals option USA in EU Łukasz_imp 7 675 02-08-2022, 12:18 AM
  Best seat option Jaychaynes_imp 14 812 07-22-2016, 04:07 AM
Last Post: Papa Weeley_imp
  Interesting option for front fork cartridge kit. kmoney_imp 5 445 12-04-2015, 01:48 PM
Last Post: spacetiger_imp
  Gazi Suspension - another option for shocks Huladog_imp 6 591 01-03-2014, 10:21 AM
Last Post: CB4ME_imp
