RE: Missed Oil Change Step?
Nortoon_imp Offline
Threads: 28
I used an open plastic (kitty litter) pan for my oil changes. But it and the funnel had to be cleaned with paper towels after each use. Oily paper towels are both messy and dangerous in a hot garage in the summer. The windows on my garage door fast the hot afternoon sun.
Taking them to the curb to degrease and wash them annoyed my tree hugging neighbour. Not too good for the neighbourhood settlement pond either which is used by frogs, ducks and geese.
So I bought this drain pan at Walmart.
The grate keeps the drain plug and washer from dropping into the hot oil. When finished the top can be capped, and the dirty oil poured out of the spout into the empty 4 liter Honda jug. Cap the spout and set drain pan aside for the next time. No need to clean it, no oily paper towels to deal with. The oil in the Honda jug goes to Canadian Tire for recycling.
05-04-2018, 02:11 AM
2017EX_imp Offline
Threads: 45
Oil Drain Container
For years, I have been using a plain round plastic pan to drain oil into. It does the job, but holding the pan with a gallon of sloshing oil in it while trying to pour it into a disposable container was not always easy, or mess free. Then there was the clean up of the pan after that oil transfer. Consequently I had been looking for a specialized self contained oil change container/pan with a pour spout to drain the oil from my bike.
I found just such a container on EBay, auction number 162121090925, on close out by Pep Boys for $10.69 shipped! The original MSRP was $30. I found the same container on Amazon for $11.90 shipped, https://www.amazon.com/Scepter-Oil-Conta...merReviews . The dimensions of the container are 11.6 long x 11.8 wide x 5.1 inches in height, and it holds 7 quarts.
The large opening that the draining oil flows into has a plastic grid to catch the drain bolt and crush washer, and has a screw on plastic cap for when not in use. There is also a second screw on cap for the pour spout for transferring used oil into a disposable container.
The predominant complaints from reviews on Amazon were for stripped cap threads from over tightening, and leakage from the caps during transport to a re cycling center, or caps leaking from storage of the old oil before going to the re cycling center. As soon as an oil change is done, I always transfer old oil from my drain pan, with a plastic funnel, into an empty plastic gallon milk jug or similar. Some folks use the empty quart bottles from the new oil. The end result is just a clean up of a plastic funnel, as there is no need or way to clean the inside of the drain pan/container. None of the container/pans of this type were recommended in the reviews for transport to recycle, and all the reviews for this type of container/pan indicated oil seepage from the caps if oil was stored in it for any length of time. Provided the container/pan is kept horizontal ( some descriptions suggested the containers could be stood on end vertically with oil inside ), the caps are not over tightened, and old oil is transferred into a disposable container before calling it a day, then no problems should be expected.
On the upside, this is a bargain priced container/pan that is of a size that will easily work with our bikes, with the plus of catching the drain bolt and crush washer with the plastic grid. Read the reviews on Amazon and decided if it is the right tool for you.
05-04-2018, 02:47 AM
tuareg Offline
Germany
Threads: 3
RE: Oil Drain Container
Agreed, that's the least messy way to change oil. I use this:
Capacity is about 14 liters, which is perhaps a bit too much. I wouldn't have 14 liters of old oil lying about in the garage.
I believe it's available on Amazon and ebay.
05-04-2018, 04:12 AM
2017EX_imp Offline
Threads: 45
I forgot to mention, whether it is this model/brand or any other of similar design, most reviewers recommend filling with water to check for leaks before actually using for oil changes.
05-04-2018, 04:18 AM
Rocky_imp Offline
Threads: 26
(05-04-2018, 02:47 AM)2017EX_imp Wrote: For years, I have been using a plain round plastic pan to drain oil into. It does the job, but holding the pan with a gallon of sloshing oil in it while trying to pour it into a disposable container was not always easy, or mess free. Then there was the clean up of the pan after that oil transfer. Consequently I had been looking for a specialized self contained oil change container/pan with a pour spout to drain the oil from my bike.
I too am a little fed up with the open pan I've been using for years. You and Nortoon have given me a great idea for the future.
Thanks to both of your for your posts Thumbs Up Thumbs Up
05-04-2018, 04:23 AM
Roper_imp Offline
Threads: 32
I use this FloTool container for changing oil in all my vehicles. $15 at Autozone. And they take back all the used oil.
[url=https://www.autozone.com/shop-and-garage-tools/oil-drain-pan/flotool-16-qt-drain-container/700706_0_0]16 qt oil drain pan
05-04-2018, 06:08 AM
Threads: 698
Likes Given: 792
How do you guys get those under your bikes? I bought one like Nortoon posted last year at Auto zone and it wouldn't fit under my ST OR my CB. I gave it to my son to use on his car.
05-04-2018, 07:57 AM
Likes Given: 1,015
When you get an answer to that Ferret, I might look at getting one that fits. Seems like a great idea to me.
05-04-2018, 08:11 AM
2017EX_imp Offline
Threads: 45
Ferret, In answer to the question, there are two sizes of this brand/model, a 7 quart, which is a 11.6 x 11.8 x 5.1 inches tall, and a 12 quart which is 21 x 15 x 8 inches tall. The 12 quart model is too large width and length to get the drain bolt centered over the plastic grid opening in the pan, aside from also being a bit too tall. The smaller 7 quart version is just about perfect for motorcycles, lawn mowers and ATVs. Something else I like, is that the drain cap for the container/pan is above the center line of the ( height ) of the pan. This means that with 4.1 quarts of oil in the drain pan, it is at a little over half capacity, and the level of the oil in the pan is just at, or just slightly above the drain cap. Other brands have the drain cap at half the height of the pan.
(05-04-2018, 02:11 AM)Nortoon_imp Wrote: I used an open plastic (kitty litter) pan for my oil changes. But it and the funnel had to be cleaned with paper towels after each use. Oily paper towels are both messy and dangerous in a hot garage in the summer. The windows on my garage door fast the hot afternoon sun.
Hey Nortoon, we both posted about the same product, the same day within 30 minutes of each other, what are the odds of that? I had not seen your post when I posted, so you desrve KUDOS for being the first to pass on the info on this time and effort saving tool!
05-04-2018, 09:52 AM
Roper_imp Offline
Threads: 32
(05-04-2018, 07:57 AM)The ferret_imp Wrote: How do you guys get those under your bikes? I bought one like Nortoon posted last year at Auto zone and it wouldn't fit under my ST OR my CB. I gave it to my son to use on his car.
It's about 24" from the center stand to the back of the front tire. So the pan I use fits fine that way. The pan is about 6" tall, which leaves only an inch to the drain plug, so I have to loosen with the socket, move the wrench, put the pan under, and then take the drain plug out with my fingers. As long as the oil isn't too hot, I'm okay Smile
05-04-2018, 01:47 PM
  Paint Change spartanheed_imp 53 3,393 02-21-2019, 02:44 PM
  Air Filter change xNE0x_imp 4 364 02-14-2015, 10:57 AM
Last Post: xNE0x_imp
  It's the little things sometimes that really change the look silascopathic_imp 10 713 08-12-2014, 10:27 AM
Last Post: Gumby 1100_imp
  cafe racer step 1 michels_imp 6 409 05-07-2014, 04:03 AM
Last Post: HikerToo_imp
  exhaust change sethrose_imp 28 1,666 03-28-2014, 08:27 PM
Last Post: Tortuga_imp
