Dart Flyscreen
regularworkingdad_imp Offline
Threads: 6
Dart Flyscreen
I apologize if this is a redundant thread, but I looked , and could not find it.
I just ordered a Dart Fly Screen. I almost ordered a National Cycle shield, but I noticed that people were cutting them down, so that they liked them more. So thinking they looked a little big on the bike, I opted for the Dart Fly Screen.
My question to those of you using the Dart is, do you like it, and how hard was it to install. It mentioned that it comes with a new headlight mount. My concern is having to re align the headlight.
07-06-2016, 01:18 PM
Frulk_imp Offline
Threads: 108
RE: Dart Flyscreen
Love my Dart. Well made. Looks good. Easy to install. You will need to refocus the headlamp because both side screws will be removed during the installation process and the headlamp will be moved around. Here's how I adjusted the headlamp. Once it's dark enough outside If you have a long driveway pick out a spot and remember it exactly and set your bike on the center stand about 15 yards away and shine the headlamp on your garage door or the back of the garage (Which is what I did to give me enough distance). I taped a sheet of paper that had a large + I made exactly were the beam center was (kinda like a scope reticle). I then wheeled the bike in the garage and put the Dart Screen on, Wheeled it back out to the same exact spot on the center stand and then fine tuned the headlamp. I will say I think I like the look of the Dart Fly screen mounts (which replace the Honda Light mounts) better than the stock ones.
07-06-2016, 03:07 PM
Likes Given: 1,011
RE: Dart Flyscreen
Or see [url=http://cb1100forum.com/forum/showthread.php?tid=905]this thread on adjusting the headlight.
07-06-2016, 10:01 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Dart Flyscreen
Dad, You can have more than one screen--its legal Tongue I use my Road Comet when its warm and put on the NC EX when it cools off. I'm not the only one who swaps screens.
I never had the Dart, but did have a Puig Plus and was surprised how well it worked. I think you will like the Dart. And heck, if not, well that's why we have a for sale section Big Grin
One hint. The headlight is held into the shell by 2 screws, and has a "hook" that goes into a plastic slot on the shell at the top. Do not pull the bottom of the headlight out too far before lifting it out of the slot. Don't want to break it.
Likes Given: 789
RE: Dart Flyscreen
here ya go RWD ...
http://www.cb1100forum.com/forum/showthread.php?tid=905
the headlight really needs to be adjusted on high beam for each individual (because differing suspension settings and differing rider weights compress the suspension changing where the beam hits (note add a passenger the rear squats down and the beam aims higher ). Adjust it on high beam because it is the most important beam especially if you ride out in the country on poorly lit roads. Usually low beam is used, where there is other ambient lighting. The two beams are fixed so adjust to the most important one.
07-06-2016, 10:06 PM
Gumby 1100_imp Offline
Threads: 17
RE: Dart Flyscreen
(07-06-2016, 10:01 PM)Lord Popgun_imp Wrote: Dad, You can have more than one screen--its legal Tongue I use my Road Comet when its warm and put on the NC EX when it cools off. I'm not the only one who swaps screens.
Am I to understand from these instructions that the nuts inside the headlight bucket are not captive and that they will fall out of position as soon as you remove the two bolts that hold the bucket to the stock headlight brackets? The Dart instructions don't suggest that the light itself needs to be removed from the bucket, or is that implied and necessary?
Thanks in advance!
07-07-2016, 01:50 AM
Lord Popgun Offline
Virginia
Likes Given: 142
RE: Dart Flyscreen
The nuts are sorta captive. They are welded to a wire clamp that fits into a space with ridges. ( sorry I can't remember exactly how well they are held in the space). Between the ridges, and the wire bundle they are mounted on the nut USUALLY doesn't move out of position. Somewhere here I have a pics of the inside of a shell. Let me see if I can find it.
OK, here it is: http://cb1100forum.com/forum/showthread....9#pid87099 Blow the pics up and you can see how it works.
07-07-2016, 02:49 AM
Threads: 17
RE: Dart Flyscreen
Thanks Popgun!
Like you, my headlight bucket is stuffed full of foam to prevent buzzing, so hopefully the nuts stay in place when I experiment with a Dart in the future.
07-07-2016, 03:02 AM
Lord Popgun Offline
Virginia
Likes Given: 142
RE: Dart Flyscreen
Mine got to where they didn't want to stay in place when I was fitting my old Puig Plus. After I took those pics, I went back and wrapped all the connectors.
I would imagine that you could put a dab of silicone to hold them in place if its a problem. Silicone or some such would be flexible enough to allow some movement as you tighten up the bolts. Or I just made sure the wire bundles hold them in the right place Smile
07-07-2016, 03:09 AM
mattmcuomo@yahoo.com Offline
Threads: 25
Likes Received: 28 in 8 posts
Likes Given: 5
RE: Dart Flyscreen
The nuts inside will move if you move things around. Or, if you try to put the bolts back in and miss you could push them in. I removed the headlight bulb, put bolts in place and put hot glue around the nuts inside to keep them in place.
Sent from me......
07-07-2016, 03:12 AM
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,867 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  Dart Marlin Flyscreen - A Quick Review the_undecider_imp 70 5,981 12-10-2019, 02:16 PM
Last Post: jimgl3_imp
  Clip-ons and Flyscreen. kmoney_imp 17 1,263 11-14-2019, 08:14 PM
Last Post: Moe_rider_imp
  Dart flyscreen and MPG rickcb 3 387 06-24-2019, 08:05 PM
Last Post: Rocky_imp
  Dart Marlin Fly screen Ennsync_imp 19 1,327 12-26-2018, 02:51 AM
  Dart Screens For 2017 EX & RS 2017EX_imp 35 2,512 12-11-2018, 01:53 PM
  Dart Fly screen chandler_imp 6 470 11-03-2018, 11:22 AM
  Could someone help me with my Dart flyscreen, please! Olyrider 6 584 09-04-2018, 01:24 PM
Last Post: SportsterDoc
  Dart flyscreen gift booboo Archie_imp 5 520 03-23-2018, 07:09 PM
Last Post: larryblag_imp
  Dart Flyscreen For Me Too! metallyguitarded_imp 27 1,971 10-07-2016, 01:10 AM
