Front Suspension Options
cblais19_imp Offline
Threads: 4
So I’m about 95% sure I’m going to be picking a ‘14 DLX up later this week from another member here, and am pretty sure I’ll want to do something to the front prior to riding season truly setting in on this coast. If my research is correct, my options are the following, in increasing price order:
-Springs / oil (RT generally?).
-Traxxion damper kit / RT valving (~$400 each way I think)
-SDBV forks from the ‘17 (~$800)
-Full cartridge (Traxxion / Andreani ~$700-1k and the latter requires modifications)
Has anybody had the opportunity to compare two or more of these options against each other? Obviously the after market kits require setup.
As far as I can tell, the biggest different in the Showa forks is a different valve setup. I haven’t disassembled the forks myself obviously, but is there a reason why the solution has been bolting the entire fork assembly on vice switching internals? The parts fiche looks identical between the two, and the EX is the same 41MM tube size as the ‘13/‘14s.
Thanks!
01-20-2019, 12:31 AM
Houtman_imp Offline
Threads: 115
RE: Front Suspension Options
I replaced my 2014 forks with the 2017 ones , VERY easy and I felt a great improvement . Is it worth $ 800 ? : that is up to you but for me it was.
01-20-2019, 02:36 AM
Likes Received: 618 in 276 posts
Likes Given: 788
Have you ridden one or just assuming you won't like the front fork actiion?
01-20-2019, 03:25 AM
For general road riding I could never really feel the difference between the traditional arrangement and "inverted". I understand all the technical benefits, however, that may benefit most while really leveraging the bike. My rides are usually weighed down with other crap, liquids and food that causes me to ride modestly.
Maybe a minor benefit: The fork seals on the inverted configuration experience less direct UV sun exposure, and possibly less prone to cracking. Thoughts?
01-20-2019, 03:45 AM
Threads: 4
(01-20-2019, 03:25 AM)The ferret_imp Wrote: Have you ridden one or just assuming you won't like the front fork actiion?
Assuming, based on the fact that a) the consensus is that the redone valving on the ‘17s made a big difference and b) my Tenere ES has ruined the suspensions of other bikes for me Tongue.
So nobody has upgraded their forks by swapping the valves around? Is there anything preventing this? As far as I can tell, that’s the biggest difference between the 14s and the 17s.
01-20-2019, 06:26 AM
Likes Given: 1,010
cblais, I've been wrong before, but I don't recall reading that anyone here has swapped the valves.
We would all be interested should you decide to try it out.
01-20-2019, 07:57 AM
chync_imp Offline
Threads: 20
I have the Adreani inserts and I love them. The front forks are now fully adjustable. Made a very noticeable difference. The springs are sized to my weight as well.
But I turned my cb into a cafe and wanted more performance.
I am considering doing inverted suspension at some point. There is a group that makes conversion triple tree for the cb.
01-20-2019, 08:11 AM
DBM_imp Offline
Threads: 16
I have a 2014 that l bought leftover a few months ago. At 4000 miles l replaced the front tire and fork oil. I used Mobil 1 full synthetic ATF at 4" from the top in both legs. I also maxed out the spring preload setting because l am 270 in full gear. Shock spring preload full stiff. Big improvment in the handling. No need for any further improvements for me. Very happy.
01-20-2019, 11:23 AM
Threads: 4
Yeeaahhh, your CB is pretty awesome. I think if I decide to shell out for cartridges I’d go for the Traxxion option, I was looking at XSR900s as well and the Andraeni cartridges need some fixing to perform optimally per the suspension guy who specializes in the Yamahas.
01-20-2019, 11:24 AM
beardyweirdy@me.com_imp Offline
Threads: 31
Adreani inserts are great. Fully adjustable, which means you'll have lots to fiddle with, which is either a pos+ or a Neg - depending on how you look at it. Once you've got them dialled in, then are a totally different world. Lots of feedback....
01-21-2019, 09:21 AM
  Rear Suspension upgrade 17-CB-002 3 348 02-22-2026, 09:41 AM
Last Post: 17-CB-002
  Windscreen Options? Yata-Garasu_imp 97 7,592 06-12-2024, 02:20 AM
Last Post: maciejman_imp
  Front fender options Azika_imp 29 3,401 11-17-2022, 02:52 PM
Last Post: Azika_imp
  Stiffening the suspension? gretle_2.0 4 580 06-23-2022, 01:15 AM
Last Post: Sparky80_imp
   Tank Guard Options Yata-Garasu_imp 11 734 05-18-2022, 08:11 AM
  Best suspension mods? gretle_2.0 6 590 05-10-2022, 06:25 AM
  Luggage Rack Options Yata-Garasu_imp 25 2,443 11-27-2021, 02:13 PM
   Handle Grip Options Yata-Garasu_imp 24 1,764 10-26-2021, 11:28 AM
Last Post: rboe
  Interesting Helmet light options satchit 1 336 06-21-2020, 02:59 AM
  Suspension Upgrade Aussieflyer 11 986 04-05-2020, 08:52 AM
Last Post: IndianRider_imp
