Sorry Guys Exhaust question again
Does anyone know if the standard 2013-16 4 into 1 will fit on a 2019 bike Im despiratly trying to find a 4 into 1 for my EX but coming up with either £1300 or nothing so was thinking of getting an older system then updating the end can with something nice
Thanks
Rob
You don't want the '13 system for your EX. Your EX has double-walled headers that won't turn dingy colors within the first 2,000 miles. It also has a much better sounding set of canisters.
It ain't broke. Don't try to fix it. Bare minimum, leave those headers alone.
Ok understand the above, but has anyone modified the standard end cans as it sounds like a Kenwood food processer not a 1140cc motorbike ??
The standard 4-1 isn't any better sounding.
Best I can suggest is keeping an eye on Ebay for some sort of a used aftermarket system to pop up.
(06-23-2020, 06:14 AM)Adventure boy_imp Wrote: Ok understand the above, but has anyone modified the standard end cans as it sounds like a Kenwood food processer not a 1140cc motorbike ??
Compared to a '13 or '14, the EX sounds like a Top Fuel dragster.
Big Grin
On my '13 I took off the end-cap and drilled a five 1/4" holes in the plate beneath. It added a nice growl without getting obnoxious. It doesn't change performance in any way. And I can always plug them with JB Weld if I ever want to revert to "food processor" mode Thumbs Up
I don't know if a '19 has a similar end-cap, so you will have to take a look.
I drilled the end plate in my '13 and it barely made a difference, and I put ten 7/16" holes in it. On my first Nighthawk 750 I removed the snooter from the pipe, cut off about 2" of it and put it back in, and it made a dramatic difference, very nice, other rides would ask me if that was an aftermarket pipe.
Arrow make one, PM me, I’ve got one spare in the loft, headers for sure but might also have a can.
I removed the end cap, cut off the snooter pipe, and drilled a circle of 5/8" holes in the plate. I reinstalled the end cap with a bead of high temp exhaust sealant around the base. I let the sealant fully cure for 48 hours before starting the bike. My bike sounds much better now with a slight growl that is not much louder than stock. The sealant helps keep the lean popping to a minimum.
beardyweirdy Ive PMd you re the above
I also drilled the first plate baffle out it had three little 1/4 holes in it ive drilled that right out with an inch bit it sounds a lot nicer now but would still prefer a 4 into 1
Rob
  Saying goodbye...no, not to you guys pdedse 7 652 12-15-2025, 11:12 AM
  Who are you guys using for shipping? phase 4 562 11-01-2025, 12:58 PM
Last Post: phase
  Hi Guys just about to buy one Adventure boy_imp 21 1,681 06-26-2020, 06:33 PM
  You guys may not like this! jdvalero_imp 11 1,411 12-25-2019, 11:41 AM
Last Post: KiowaEagle_imp
  Take care of yourselves guys... Randy B 39 2,710 11-22-2019, 08:19 AM
Last Post: Chuckk_imp
   Exhaust question Gremlinsteve_imp 15 1,331 10-16-2019, 08:53 AM
Last Post: jdvalero_imp
  What Motorcycle news sites do you guys look at? iamlegend21087_imp 12 959 11-06-2018, 01:11 PM
Last Post: Stichill
  What do you guys think of this tank? PowerDubs_imp 41 2,346 08-13-2018, 11:25 PM
Last Post: jitaylor_imp
  I DID IT!! Thanks to you guys. iamlegend21087_imp 16 1,221 06-16-2018, 04:34 AM
Last Post: locomotive engineer_imp
  Exhaust question LouA_imp 3 295 01-06-2016, 02:35 PM
Last Post: Rick Froscheiser_imp
