2014 rims vs. 2017 spoked rims---will they fit?
cyclehooptrain_imp Offline
New to the Forum
Threads: 1
Hi--Hoping an expert or two can give me some thoughts, as Honda has been not too helpful with my local dealer. I have a 2014 CB1100 EX (the rare silver engine model) that we are using as a basis for a modern replica of a 1969 Sandcast. We have everything we need EXCEPT the spoked rims. While I can order some from samurider at $2700, I am wondering if I can use those from a 2017 CB1100 and order them direct from Honda for much less. My biggest concern is fit, of course, and if I order and they are wrong, I can not return them. Any ideas if these (or something else?) will work? They MUST be chrome rims and spokes. Thanks!
04-28-2020, 09:46 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: 2014 rims vs. 2017 spoked rims---will they fit?
I believe only the RS model has 17” Wheels and we did not get that model in the US. I don’t know if a US dealer could order the wheels and parts, but MR. T at samurider can.
I do not know if they will fit though. I tried searching on the board but lots of discussion and no real conclusions. Although I did run across an embarrassing error in one of my posts Sad
04-28-2020, 10:48 AM
Likes Given: 1,012
Wasn't there a discussion recently about this? I'll look a bit later and see if I can't find it, although if Lord Popgun has failed, I won't have much chance. There are questions of axle size between different models, aren't there?
[url=http://cb1100forum.com/forum/showthread.php?tid=1974&pid=130363#pid130363]Here's a post about Aussieflyer's conversion of his standard rims to spoked ones.
Lord Popgun, PM or email me about the embarrassing post and I'll fix it.
I think [url=http://cb1100forum.com/forum/showthread.php?tid=12759]this was the thread I was thinking about. It is talking about going the other way: putting DLX mags on a 2017 EX. It does point to some potential problems.
By the way, cyclehooptrain, some pictures of your work would be interesting.
04-28-2020, 01:06 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Regarding the cost of the new Honda 2017EX wheels, they won't be cheap either. Here's a price list of the major required parts, with pricing from an online dealer (hondaparts-direct) that I find the least expensive. Your findings may vary.
Front: (an assembled wheel with spokes would be $167 more)
hub $173
rim 183
pulser ring 18
disc rotors 610
disc bolts 11
tube/rim strip 25
wheel spacers 15
front subtotal $1035 (stock wheel $1202)
Rear: (an assembled wheel with spokes would be $103 more)
hub $280
rim 231
tube/rim strip 28
wheel spacers 26
caliper bracket 97
brake hose 37
drive flange 128
rear subtotal $827 (stock wheel $930)
If it has to be chromed, Buchanan's chrome spokes and nipples are about $300 per wheel, and $100 per wheel lacing and truing them up, plus the price of chroming the rims (estimated $200-300 each), so another $1200-1400.
I am waiting for some ordered parts, so next week I will be converting my 2017 EX to 2014 DLX wheels. I will start a new thread on it then, and see if the caliper bracket, brake hose and drive flange truly need to be replaced when swapping wheels.
04-29-2020, 03:40 AM
Houtman_imp Offline
Threads: 115
I am very interested in this conversion and will follow your tread to see how it goes . If all well I might do the same , not for looks but to help when getting a flat on the road.
04-29-2020, 10:38 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
I was able to determine that yes, you definitely need the new drive flange, brake caliper bracket, and the hose, plus a new speed sensor ($119).
Because the wire spokes need to be outboard a little more at the hub to triangulate side-to-side force, the disc is outboard more, meaning the caliper would have to move outboard and hit the shock.
04-29-2020, 12:51 PM
  2017 EX Horn on a 2014 Std CaptainChris_imp 27 2,056 10-20-2021, 04:48 PM
  HONDA OEM SPOKED WHEELS for CB1100 CB4ME_imp 21 1,534 11-28-2018, 06:11 PM
Last Post: FLYTYM_imp
  2017 Chrome Gauge Covers on a 2014 suhawk305 12 876 08-01-2017, 12:27 PM
Last Post: run-tmc_imp
  Wonder if the 2017 quasi grab rail would fit my 2014 Deluxe? TINK_imp 2 325 06-13-2017, 12:31 AM
Last Post: baxtercat_imp
  New Rims rusty1_imp 21 1,249 02-08-2017, 10:23 AM
  Black Finish on Rims Question Steverino_imp 1 257 01-18-2016, 12:10 PM
Last Post: Carguy1959_imp
