Bungee tie down points
Sledge13_imp Offline
Threads: 1
I would like to add these tie down points. Has anybody else done this or could point me to the parts to do it? Thanks! [Image: c147355be38fd974e58d73f851d3310c.jpg]
04-26-2020, 02:11 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: Bungee tie down points
Use the top shock bolts off a 2017 EX, 90116-MGC-JB0. The washers are the same.
04-26-2020, 03:29 AM
the Ferret Online
Likes Received: 582 in 260 posts
Likes Given: 767
careful on torquing those top shock bolts. Several have broken them off.
04-26-2020, 06:19 AM
Threads: 1
(04-26-2020, 03:29 AM)pekingduck_imp Wrote: Use the top shock bolts off a 2017 EX, 90116-MGC-JB0. The washers are the same.
Thanks pekingduck. I ordered them off of BikeBandit.
04-26-2020, 07:06 AM
Houtman_imp Offline
Threads: 115
I have used a lot of these over the years and always bought high quality bolts for them . Be careful when strapping things down as it is easy for bungee cords to come of these "bolts"
04-26-2020, 07:11 AM
Threads: 1
(04-26-2020, 07:11 AM)Houtman_imp Wrote: I have used a lot of these over the years and always bought high quality bolts for them . Be careful when strapping things down as it is easy for bungee cords to come of these "bolts"
Good advice. I have been using Rok straps for awhile now. They seem better than the hooked variety.
04-26-2020, 07:14 AM
Houtman_imp Offline
Threads: 115
Yes , for the last 5 years I have been using the Rok straps as well , much safer and easy to use on bigger loads.
04-26-2020, 07:28 AM
Threads: 1
(04-26-2020, 06:19 AM)The ferret_imp Wrote: careful on torquing those top shock bolts. Several have broken them off.
Thanks I will err on the side of caution.
04-27-2020, 05:31 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
The spec for the original bolt is 6.6 ft lbs. That isn't much.
04-27-2020, 06:12 AM
Threads: 1
So I finally received the bolts (more than a month for shipping) for these additional tie down points and am very happy with them. Did not over-tighten them. Thanks
06-01-2020, 01:44 AM
