Sissy bar and rack.
Swartzracer_imp Offline
Threads: 14
Sissy bar and rack.
Here is pic of my retro fit sissy bar and rack. I purchased it new on eBay. $59 dollars free shipping. I am pleased with it but I think I will have the side plates re chromed this winter.
08-02-2014, 09:50 AM
Pterodactyl_imp Offline
Threads: 75
RE: Sissy bar and rack.
Looks good. It will sure keep your pillion happy.
08-02-2014, 07:44 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
It does look good! And with that new chrome it will look even better!
08-02-2014, 07:57 PM
Likes Given: 1,010
08-02-2014, 08:32 PM
crescent curve_imp Offline
New to the Forum
Threads: 1
Looks great, Swartzracer. Is that the carrier and backrest from a Honda Shadow that you were mentioning? Did you make your own brackets to mount it? If so, do you have a pic of the bracket you made? It's always helpful for other owners out there that are looking for backrest options. I think this is the first time a backrest was attached without using a 2013 or 2014 CB1100 carrier rack (or Corbin seat with the built-in). Thnx-
08-03-2014, 02:52 AM
Threads: 14
Yes it was originally made for a 2007 honda shadow. I used the brackets that came with them. I just switched the right and left around for the offset bends. I had to trim the brackets to fit and drill one new hole in the bracket. The side plates wouldn't need re chromed if I would not of had to switch them from side to side. The chrome on the back of them is not like the front of them. Everything for $59 bucks is a pretty sweet deal. It took me about 2 hours to make it work. Now that I know how to trim the brackets I could do the job in an hour.
http://m.ebay.com/itm/310802495941?nav=SEARCH
08-03-2014, 04:47 AM
1ate7records_imp Offline
Threads: 1
Do you think it would be possible to remove the back rest if wanted & put a givi top case on that rack?
08-12-2014, 01:14 AM
Lord Popgun Offline
Virginia
Likes Given: 142
1ate,
I bet you could easily. Mount the Givi mount to the rack and the box to the mount.
08-12-2014, 01:34 AM
CBToby_imp Offline
New to the Forum
Threads: 0
Swartzracer.
I really like what you've found and went to the eBay site. They ask for a sub model. Can you tell me which one you used?
08-19-2014, 07:50 AM
Likes Given: 1,010
Sissy bar and rack.
(08-12-2014, 01:14 AM)1ate7records_imp Wrote: Do you think it would be possible to remove the back rest if wanted & put a givi top case on that rack?
I had a Shadow and I did just that: removed the backrest and attached a Givi topbox to the rack. Worked really well.
08-19-2014, 08:32 AM
  a better sissy bar j3gq_imp 19 1,369 11-19-2021, 05:48 AM
Last Post: j3gq_imp
  vintage sissy bar Tom_imp 27 1,827 08-12-2021, 07:59 AM
Last Post: j3gq_imp
  Sissy Bar - FINALLY! c-breezy_imp 30 1,789 08-13-2020, 04:14 AM
  rear rack/back rest / sissy bar jitaylor_imp 5 563 05-09-2018, 06:05 AM
Last Post: Roper_imp
  Sissy Bar (Back Rest) larryblag_imp 6 571 04-07-2018, 07:19 AM
Last Post: Reiver_imp
  Sissy-bar Mike79_imp 14 842 07-03-2016, 09:53 AM
Last Post: Biggin_imp
  Does anyone have steps for Honda Shadow rack/sissy bar modification? goldeneye_imp 0 231 08-18-2015, 09:36 AM
Last Post: goldeneye_imp
  Why no stock sissy bar? Red1100_imp 12 821 02-24-2014, 10:38 AM
Last Post: pwyakjr@stny.rr.com_imp
  What about a "Sissy Bar" JeffsCB_imp 10 753 08-21-2013, 06:42 AM
Last Post: scott will_imp
