Head light died
Hello Cb 1100 frined s,
I was lucky last night whern I pulled the Cb1100 to ride , every thing fine , until the head light died on me (both the hi and low beams), bike was at idling before even moving .prior to that like twice it started blinking on me and then completely dark. every thing else including the gage and rear running lights are ok , the only strange thing is that hi and low beam not working both and Also the blue light at gage i also on for both hi and low beam . what could it be ? I am thinking fuse , is there a fuse box for CB1100 and where, I am going to try to find the OEM light that I replaced with
the expensive direct plug and go replacement one from ADVmonster .but before doing that do you think it might be something more than light or fuse ?
Thank you
Ride safe /Ride longSmile
I had the same problem but easily could have died !
Last year I replaced the H4 headlight on my CB 1100 2013 and 2014 with a LED light from ADVMONSTER , after only a few weeks having the LED light I came into a tunnel on the BRP and suddenly It was all dark on both beams and I nearly died from fright !
Slowly I rode out of the tunnel and realized that the fuse had burned. When at home at put a new fuse in and a H4 bulb and all was ok . I also took the LED out of my 2014 and contacted the company , they send me replacements which I put in my wife's CRV
DO NOT USE THEIR LED 'S THEY WILL GET YOU KILLED AT NIGHT OR IN A TUNNEL !!!
(07-20-2020, 10:06 AM)Houtman_imp Wrote: I had the same problem but easily could have died !
Thank you for your prompt response , I am sorry for your horrifying experience . I am going to replace it with a OEM now after your experience , I don't know how ever where the fuse box is. could you please show me where to look for it?
Thank you
Ride safe /Ride longBiker
It’s under the seat, above the battery toward the rear next to the rear brake reservoir. Remove the tool box if needed.
(07-20-2020, 10:28 AM)Lord Popgun_imp Wrote: It’s under the seat, above the battery toward the rear next to the rear brake reservoir. Remove the tool box if needed.
Thank you so much .Thanks
Ride safe/Ride long Biker
Pterodactyl has had some problems with his low beam as a result of a dirty connection in the starter switch in the throttle grip. I think it's because there's a circuit that switches the head light off as the bike cranks. He's had dirt in there which has resulted in the light not coming on again after the bike has started. I can't remember now whether it affects the high beam.
Crappy parts = problem
OEM, very unlikely. 0.02
If the fuse was bad, the blue high beam indicator wouldn't come on at all. The high beam indicator now comes on whether on high or low beam because both circuits are connected inside the bulb on the ground side. So you'll get power to the high beam indicator all the time, but no high or low beam because the bulb itself is not grounded.
I'd look for a bad ground wire connection (green) outside the headlight. Don't blame the bike if you've been adding accessories or prowling around inside the headlight case. Idea
In my case it was the LED light itself , I told the Company that those lights are a law suit waiting to happen. They were not even cheap .
(07-20-2020, 11:01 AM)pekingduck_imp Wrote: If the fuse was bad, the blue high beam indicator wouldn't come on at all. The high beam indicator now comes on whether on high or low beam because both circuits are connected inside the bulb on the ground side. So you'll get power to the high beam indicator all the time, but no high or low beam because the bulb itself is not grounded.
Sorry, meant to say to look for a bad ground wire connection (green) outside the headlight bulb.
  Head oil seepage normal? PowerDubs_imp 20 1,141 10-12-2016, 11:23 AM
Last Post: 736cc_imp
  Steering Head Shake and Bar Grip. Pterodactyl_imp 16 1,035 10-03-2016, 03:52 AM
Last Post: Rolls_imp
  Russ Collins died Ridem32_imp 2 246 05-13-2014, 08:18 PM
  DidI tell you how much i love chrome head pipes? the Ferret 17 1,136 04-15-2014, 12:10 AM
Last Post: rboe
  Made her a place at the head of the line hondahoarder_imp 5 400 06-30-2013, 07:08 PM
Last Post: Guth_imp
