BikeVis Bullet LED's (modulated)
Tev62 Offline
Threads: 33
Fitted some BikeVis bullet LED's to the CB the last couple of days. I took the side panel aux connector and triggered a relay to power them. The current draw is so low I didn't need a relay but did want to just switch them on ignition and segregate them from Honda's electrics.
I also used their modulator which twinkles the lights for added effect. This is just a little video of how they look, I have a longer one going up in a few more days with the whole install.
https://youtu.be/YuBhOBI7rR8
12-29-2020, 11:04 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 244
Likes Received: 1,118 in 477 posts
Likes Given: 898
RE: BikeVis Bullet LED's (modulated)
Those are pretty cool. I used to have a pair on my Nighthawk 750. I stuck them on the edge of the front reflectors on the forks. They don't even register as far as power draw, if I recall I tapped into the headlight, and didn't run a switch for them.
I like the "triangle of light" pattern that sets you apart from half-a-car a car at night.
12-29-2020, 11:08 AM
peterbaron Offline
Likes Received: 572 in 311 posts
Likes Given: 953
Looks good, neatly done job with brain = Thumbs Up
12-29-2020, 11:11 AM
Interesting video Tev. Thumbs Up Those mini LED torches are probably useful in other unique areas with the use of some "grey" 3M VHB adhesive. Hmmm. Idea
12-29-2020, 12:09 PM
Tev62 Offline
Threads: 33
(12-29-2020, 12:09 PM)GoldOxide_imp Wrote: Interesting video Tev. Thumbs Up Those mini LED torches are probably useful in other unique areas with the use of some "grey" 3M VHB adhesive. Hmmm. Idea
Yes, lots of different colours too. The red would make some great extra rear visibility. Good value too I thought. The power lead comes out of the base so you do need to think a little on mounting points. They do have a sticky base on them which has proved reliable on my other bikes.
12-29-2020, 07:43 PM
Gone in 60 Offline
Orange County, CA
Threads: 244
Likes Given: 898
Oh yeah, forgot that the lead comes out of the base. As I remember now, I fabbed up some little metal tabs with a hole to run the wire, and 3M taped the tabs to the backs of the front reflectors.
12-30-2020, 03:08 AM
(12-30-2020, 03:08 AM)Gone in 60_imp Wrote: Oh yeah, forgot that the lead comes out of the base. As I remember now, I fabbed up some little metal tabs with a hole to run the wire, and 3M taped the tabs to the backs of the front reflectors.
Thumbs Up
Really not a bad thing. I am sure most capable Forum folks can work with the configuration.
12-30-2020, 06:17 AM
