pdedse
Threads: 119
Likes Given: 814
RE: Thought experiment: $2500 worth of improvements to the CB1100
(05-29-2020, 01:05 AM)misterprofessionality_imp Wrote: It is a tall order! i'm exploring the idea in the name of sentimentality though. I love my CB. the truth about an FJR or a ST or a R1200 is that they aren't a CB1100, and more than that they aren't my CB. Those bikes are all objectively better than my bike but none of them are good enough to make me sell my bike. The tallest order of all is for something to be good enough that I want to sell my CB. None of this is set in stone. these are just two equal and opposite ideas that beg exploring. I can shell out 5 or 6k for a replacement bike or I can keep my CB and shell out 2500 this year, 2500 next year, 2500 the year after that to make sequential improvements.
What i'm looking for is an alternative that doesn't put a redundant bike in my garage or force me to sell my CB. Thus, the idea of simply improving the CB occurred to me.
I haven't exactly given up on the C14, it's just that this idea is an alternative counterpoint to the idea of getting a C14. I also have a line on a very gently used BMW K1300GT, which i understand is even better than the C14. But again, i'm very strongly leaning toward finding an option that lets me keep my CB.
(05-29-2020, 01:04 AM)pdedse_imp Wrote: (05-28-2020, 11:54 PM)misterprofessionality_imp Wrote: I've been back and forth lately on what direction to take my CB next. I've found myself in search of an added safety aspect to my daily motorcycling. I realize that as much as I love the CB it is still built like an obsolete bike. It does not have ABS, it has a relatively low fuel capacity for its displacement, it has a relatively less effective suspension in its stock format. We all know there are many other things about the bike that don't quite stand up to modern standards (and it was never intended to, that's part of its charm).
So, in order to act as a counterpoint to the idea of purchasing a secondary sport-touring variety motorcycle to act as a primary commuter with modern safety and creature comforts, i've decided to explore the idea of spending all that money on making improvements to my CB instead. Thus, as a thought experiment i'm posting here to collect ideas on the best/most comprehensive improvements I can make to a 2014 CB1100 Std. with approximately $2500 cash available.
Some options that have interested me so far:
** fuel capacity : $900 (tank off a '14 DLX) increase my capacity to 4.6 gallons. edit: alternatively if i could find a Whitehouse K10 tank on the forum for cheap that would be 4.7 gallons! but i'm not gonna pay 2000 bucks for one new.
** ABS: This is kind of up in the air...I tend to think that If i can purchase a salvage/crashed bike with all the necessary parts undamaged i can get away with this for about $1500. It's not going to be easy to find a crashed '17 though, unless somebody knows of a resource.
** suspension improvements (front and rear): the cost here is probably more than $2500 if i go to the top end. I would appreciate it if anybody can point me toward some front and rear suspension improvements that would make a real difference for less than $1500.
** Seat: K&H solo or Mid Double seat to improve comfort : $600
** Wheels: Converting to spoked wheels would allow me to swap tire sizes and mount the better tires on the market that I currently don't have access to. I can't speak to the cost of this. It may be something that has to go hand in hand with the ABS change, since part of that could potentially involve using the '17 wheels.
** LED headlamp. I'm lost on this one. I imagine it's just a matter of adding an LED component and using the LED lamp off the newest models, but I don't know for sure. anybody that knows more about doing this please chime in.
** heated grips: $150 (oxford heaterz!)
Edit** accessory power connectors!! $50. being able to plug in a GPS and other powered accessories like heated gear is an upgrade i've wanted to make for a long while.
Obviously I can't do all of these at once, but it's worth thinking about the various options that are out there. What about all of you? if you had $2500 to spend improving your CB, what would you do?
Based on your experience, you've determined your '14 DLX needs "added safety" because '"it is still built like an obsolete bike". There will be differences of opinion on that, but you're asking because you want some imput.
If "added safety" is your main motivation for the possible changes, I'd go through the list and ask myself which modification adds the most safety and which one adds the least.
As an example, for me: tank size probably doesn't add much "safety"...and it's $900. Bigger tank gives you an extra 1/2 (?) gallon of fuel. Has that been a problem? An inconvenience from time to time? Maybe you do long trips in low populated areas, and then it might be a safety issue. If not, I'd put that at the bottom of the list....unless, maybe you want to play with a different color of tank, and then we're talking more about aesthetics and less about safety. I'm actually thinking of changing to a blue tank--just think it would look really cool...but I'm not sure if it would look $900 more cool.
On the other hand...heated grips: seems like a huge improvement for the expenditure, and adds lots of safety in the way of more comfortable ride, having greater dexterity / response with hands.
I'd also say listen to your own thoughts. I know for me that on more than one occasion, I listened to what others talked about (mainly online chatter) about "improvements" that one "just had to do" to X brand of bike to make it more comfortable, better handling, more this/that. Some were legit, but some ideas were things that others wanted, and not really what I needed or wanted. I realized that after making certain "improvements" that ended up simply being changes and not improvements.
Back to the bottom line question: "if you had $2500 to spend improving your CB, what would you do?"
If I had that money, the "improvement" I'd make would be to update my worn travel luggage, tent, camping gear, and leave the rest of the money to do an extended trip wherever I most wanted to explore.
I appreciate your post but i have to immediately point out that my '14 is a STD not a DLX. honestly if i had a DLX we wouldn't be havin this convesation
Added safety is #1 but i'm also going for more of the kinds of creature comforts that come with more modern bikes. since i'm a full time commuter, increased range is important. it's about a 1 gallon difference from the STD tank at most.
Yes I read right through "standard" and typed DLX w/out double checking ... wasn't putting 2 and 2 together. : )
