Taking apart my Blueskysea dashcam model DV988
17-CB-002 Offline
Threads: 45
My dashcam stopped working after I inserted the memory card. It seemed that the memory card went in sideway and fell into the casing.
So I had the choice to take it apart or worst dispose of it completely.
Armed with a jewellers screw driver kit, I took a chance, removed all the screws (16) and rubber plugs and separated the two shell. Located the memory card lying at the bottom under the printed circuit, using a tweezer I cautiously retrieve it out and then put everything back together with no extra screws/plugs left over Rolleyes
After installing the dashcam back on the bike, I successfully tested and confirm for proper operation. Banana
06-23-2021, 01:35 PM
Likes Given: 1,010
RE: Taking apart my Blueskysea dashcam model DV988
Brave man, Alain.
06-23-2021, 09:32 PM
(06-23-2021, 01:35 PM)Alain Lee_imp Wrote: My dashcam stopped working after I inserted the memory card. It seemed that the memory card went in sideway and fell into the casing.
What the?
06-23-2021, 09:44 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Yeah, could you show us EXACTLY how you did that? Tongue
Cause I have one of those and don't want that to happen. Confused
06-23-2021, 09:51 PM
peterbaron Offline
Likes Given: 996
(06-23-2021, 09:51 PM)Lord Popgun_imp Wrote: Yeah, could you show us EXACTLY how you did that? Tongue
Mi Lord, Alain showed me his pics and dash cam today with the memory card inside... you'd better not to play with it EXACTLY how he did..TongueBig Grin
06-24-2021, 06:19 AM
17-CB-002 Offline
Threads: 45
Hi LP, no need to worry too much.
Only precaution required is to take your time to insert it "straight" down into the slot and with proper lighting to see what you are doing.
My DashCam control module is positioned at an angle so that I can view the screen while riding, so under dim lighting condition I inserted the memory card sideways into the slot and missed. If not careful it will miss the correct point of entry and drop into an empty slot.
I always take the memory card out of the dashcam to download the pictures faster on my computer and I got caught this time Angry
06-24-2021, 07:43 AM
  Racks and model years Classico_imp 14 1,964 07-04-2022, 01:01 AM
Last Post: 1973cb750
  Dashcam for motorcycle 17-CB-002 55 3,765 08-19-2020, 05:24 AM
  2017 base model - fender eliminator kit Dubai1100_imp 17 1,622 10-31-2019, 09:53 AM
Last Post: chync_imp
  CB 750 model scale 1:4 with sound/light alprider 2 293 04-10-2018, 01:42 AM
Last Post: alprider
  Where to find Brake Lines (ABS model) ? mrbi0_imp 5 485 05-15-2017, 05:48 PM
  MRA VarioScreen (model VNB) ScottWally_imp 8 697 04-12-2016, 10:46 AM
Last Post: ScottWally_imp
  EX model seat OndaCB1100_imp 12 764 08-29-2015, 05:36 AM
Last Post: Rick Froscheiser_imp
