Kawasaki H2
This is really big news:
http://www.visordown.com/motorcycle-news...25467.html
The article doesn't say it, but this will be the first forced-induction motorcycle in what, 30 years? A true paradigm shifter.
Now if Suzuki would just put their Recursion into production...
Next collectible after the turbos of the 80s.
Supercharger have even more lag than turbos, wonder how they will get the low RPM range to perform.
(09-02-2014, 06:45 AM)CIP57_imp Wrote: Supercharger have even more lag than turbos, wonder how they will get the low RPM range to perform.
No. Superchargers give instant boost based off drive % and RPM as they are direct drive. Turbos need to spool. However, turbos are more thermodynamically efficient.
I've always seen superchargers make more boost at lower RPMs in similar applications... almost zero lag when compared to turbos... would this change in such a small engine? The smallest motor I've seen both on is only a 2.0L
Sent from my Z30 using Tapatalk
Honda: "The Power of Dreams"
Kawasaki: "Making Dreams Come True"
This "evocatively named" bike will be really interesting.
When I saw "Kawasaki" and "H2", I had an entirely different post in mind.
Although one of my favorite bikes ever was the GPz 750 turbo of '83, I'm not a general fan of unnaturally aspirated engines on motorcycles. Probably because most have been attempts to bolt an aftermarket turbo/supercharger to an engine that wasn't designed to use it.
Looks like Kaw is going for a ground up build with resources that actually know a lot about compressing air with turbines (aerospace dudes). I'll be interested to see what they come up with.
Tradition is fine, but they should have at least considered calling it the H3.
BTW, my first ride on the original H2 was simultaneously the most exciting and frightening bike I ever rode up to then.
I used to own a 1975 purple H2 , exciting bike ,terrible mileage .
The one thing that I did not like was the " surging " when closing the throttle.
Below is a good read.
http://auto.howstuffworks.com/question122.htm
Supercharges need HP to produce HP therefore most of the HP gains are at the top of the RPM range. There will be dead spots unless they can figure out how to get torque up at the lower rpm range.
"The biggest disadvantage of superchargers is also their defining characteristic: Because the crankshaft drives them, they must steal some of the engine's horsepower. A supercharger can consume as much as 20 percent of an engine's total power output. But because a supercharger can generate as much as 46 percent additional horsepower, most think the trade-off is worth it."
(09-02-2014, 03:44 AM)The Spaceman_imp Wrote: This is really big news:
My bet is that forced induction will eventually become standard because ever-increasing emissions regulations (which will become even much MORE restrictive now that electric bikes are being sold and regulators can claim that 'zero-emissions vehicles' are viable) will force all motorcycle manufacturers to eventually run forced induction, water cooling, super lean fueling, expensive and trick alloys to handle high normal operating temps, and fewer cylinders with smaller total engine displacements. Even Harleys will be forced to toe the line.
Buy your literbike normally aspirated air cooled CBs while you can!
  2022 Kawasaki Z650RS peterbaron 216 14,328 08-01-2026, 02:22 PM
  Kawasaki Z400GP...and next prime minister? pdedse 1 296 10-16-2025, 12:07 PM
  Kawasaki W400 Cormanus 17 1,358 09-27-2025, 01:37 PM
Last Post: tdbru
  The Kawasaki W230 is coming! misterprofessionality 17 1,369 10-04-2024, 03:22 AM
  2021 Kawasaki W800...blue pdedse 29 1,981 10-08-2023, 10:25 PM
  2020 KAWASAKI W800 REVIEW: RETRO MOTORCYCLE (14 FAST FACTS) GoldOxide_imp 52 2,996 08-16-2022, 06:08 PM
Last Post: Wisedrum
  Kawasaki Ninja 250 Tev62 14 1,236 08-12-2022, 06:06 PM
  Kawasaki Z900RS motoWest_imp 19 1,220 06-25-2021, 09:43 AM
  Opinions on the Kawasaki Concours 14 misterprofessionality 31 1,676 06-10-2020, 02:37 AM
  Another great Kawasaki Z1 restoration postoak_imp 14 929 02-10-2020, 12:26 AM
Last Post: postoak_imp
