OOPs I did it again
So after buying a 1973 DT100 just for fun, this little gem shows up on CL. 1982 DT100 with only 163 miles showing on the clock. It is not pristine but I couldn't resist.
Ahh...2 stroke simplicity!
Beautiful!
Nostalgic fun and those little things can flip you Thumbs Up
Ah, those old ones have timing chain issues....... Dodgy
I thought they used timing belts, not chains...
Uhh.... no timing chains, no timing belts.. the timing was all static mechanical- the physical location of the ports in the cylinder.
Why would you need a belt or a chain when there are no valves, no cams, and therefore no rotational driven opening mechanism?
......and a lots of mods with ports, exhaust and intake were done with 2-stroke without spending a lot of money...lovely rpm with high "C" sound Thumbs Up
pb
Cheap and easy- no need to buy high performance camshafts, no need for bigger valves, no need for different valve springs.
Where's my dremel? was all you needed to know.
Somehow I don't think I am going to turn a 100cc trailbike into a raving 2 stroke monster Smile
  Oops. misterprofessionality 16 1,118 03-31-2023, 02:11 AM
   Oops! DGShannon_imp 5 450 02-15-2015, 08:54 AM
Last Post: Pterodactyl_imp
