Monkey in the mountains
I brought my Monkey home in December and rode it a few times before the weather turned bad. On those rides, the bike struggled on our steep, hilly roads (I'm at 8000') and was sucking gas. Even though it's fuel injected, the shop manual has a section which describes how to adjust the ECU for high-altitude riding. The adjustment requires a special tool (a jumper), which I purchased, and a sequence of opening and closing the throttle with the ignition on. I made the adjustment a few weeks ago but didn't have a chance to ride the bike again until today. All I can say is wow, what a noticeable difference. Now the bike will pull the hills with a degree of authority. It really scoots along (up to about 50 mph). Huge difference!
i will see in summer how much power i will lost by your level...if i will makes my loops in our alps...
Ha ha very cool LR.
Trippin on the Monkey...
Nice that the adjustment was available to you. Well done LR.
I suppose it makes sense since Honda can't control where their products will be used throughout the globe.
True, but I always thought fuel injection "self-adjusted" for altitude, based on sensors or whatever. This was the first I heard of having to reset an ECU to manually change the air/fuel map.
Great news, LR! I know you were a bit concerned about the hill-climbing ability.
(04-06-2019, 10:52 AM)LongRanger_imp Wrote: True, but I always thought fuel injection "self-adjusted" for altitude, based on sensors or whatever. This was the first I heard of having to reset an ECU to manually change the air/fuel map.
Maybe on this "grade" of vehicle, the range of region adaptation is limited in scope and needs manual intervention on out-of-limit situations. Just speculation. Possibly, higher-end vehicles like the Gold Wing, Honda Accord, etc. auto-adjust due to access to richer sensors and resources.
That's what I was thinking as well. My guess is that the ECU on the Monkey is probably a bit more simple (i.e. fewer sensors) than what would be found on a larger, more expensive bike.
I know my CB11 adjusts to altitudes in the Rockies quite well.
m in sc, you're the one who alerted me to the ECU adjustment, and I thank you for that. I would have never known to question it otherwise.
(04-08-2019, 04:36 AM)LongRanger_imp Wrote: m in sc, you're the one who alerted me to the ECU adjustment, and I thank you for that. I would have never known to question it otherwise.
It would have been nice if your dealer knew about this and had taken care of it if the dealer had any idea you would be using the Monkey at high altitudes.
  monkey with 100000 km alprider 3 377 10-30-2023, 09:09 AM
  2022 Honda Monkey Olof_imp 7 774 05-30-2022, 07:37 AM
  Monkey OTD Price HondaJon_imp 27 1,633 08-16-2021, 09:39 PM
  Monkey Mods 2017EX_imp 1 260 04-22-2020, 07:33 AM
  Monkey Monkey alprider 123 7,398 02-17-2020, 02:44 AM
Last Post: Razor
  Baja 1000 on the Honda Monkey LongRanger_imp 5 389 12-31-2019, 12:59 AM
  Ohlins Monkey Gone in 60 3 312 12-17-2019, 01:31 AM
Last Post: alprider
  2020 Monkey, Vintage Comparison, & Mods 2017EX_imp 20 1,497 11-27-2019, 07:32 AM
Last Post: 2017EX_imp
  a CB is only a monkey alprider 9 609 05-08-2019, 05:40 AM
Last Post: Doc1961_imp
  Gorilla vs. Monkey Bike Impressions ChipBeck_imp 6 475 01-15-2019, 11:57 PM
Last Post: Capo
