Rear ABS Disc
So I realized that my rear wheel has the smaller ABS Disc on it. My CB is supposed to be the non-ABS version. Any input?
(11-20-2013, 11:11 PM)gogoAZ_imp Wrote: So I realized that my rear wheel has the smaller ABS Disc on it. My CB is supposed to be the non-ABS version. Any input?
That slotted disk would be the limiterAngry
Correction. That slotted disk is part of the vehicle speed sensor. The limiter is in software in the ECU.
In contrast to older bikes where the speed was measured with a wire from the front wheel, nowadays (at least Honda) bikes measure their speed on the rear wheel with this slotted disc (on ABS and non-ABS bikes). It also serves as ABS signal meter if you have ABS.
Thanks for the info.
  Brake disc rubbing noise mrded_imp 8 727 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
  CRC Disc Brake Quiet Houtman_imp 45 3,062 01-29-2021, 12:58 PM
  New Rear Tire and Rear Brake Pads memphismike_imp 5 567 06-11-2018, 09:35 PM
