Threads: 27
Ok Gang,
Noticed the tread is getting low of my PR3's and I am starting to look at replacing them. I want some that will give me the same range that I got from them (close to 10,000 miles). I'd also like to know what different sizes people have used. Thanks guys.
Threads: 5
Likes Given: 34
If you haven't already tried them, might wanna check out the Pirelli Angel GT's in 120/160 sizes. Others here have said good things about them and they are actually on sale right now @ Revzilla(~$250) for a set.
I will be getting mines mounted tomorrow so can't give you an opinion right this moment, but should be able to sometime on Sunday
http://cb1100forum.com/forum/showthread.php?tid=15686
Threads: 27
(07-17-2020, 03:50 AM)E11even_Hunnit_imp Wrote: If you haven't already tried them, might wanna check out the Pirelli Angel GT's in 120/160 sizes. Others here have said good things about them and they are actually on sale right now @ Revzilla(~$250) for a set.
Thanks for the info, but it looks like the sale is over. I am seeing (front) $130.99, and (rear) $150.77. Was that $250, including the $25 coupon?
Threads: 115
I really like my PR 4 on my CB 110 (fronts only I have Continentals 150 on the back
Likes Received: 586 in 321 posts
Likes Given: 991
(07-17-2020, 06:32 AM)Houtman_imp Wrote: I really like my PR 4 on my CB 110 (fronts only I have Continentals 150 on the back
John, what exactly you have on the back??
Threads: 115
Peter ,on my 2013 I have a 150/70 Conti Trail Attack 2 and on my 2014 a Conti Trail Attack 3 , both 90/10 tires.
I never go off road but they are very good on the road , check Continentals website for info about the tires and you see what they are. I very much like them and although many guy's put a 160 Michelin on the back without issue's I personally find it a little too wide for the rim.
Likes Given: 991
Gotcha, thanks John
Is very hot in S/Ontario, 40*C/104*F...any cold beer??
Threads: 115
I am trying very hard to keep Sierra Nevada's North Carolina's brewery in business , not hard to do in these hot days.
Threads: 72
Likes Received: 24 in 7 posts
Likes Given: 7
Tried Pirelli Angel GT pair ... ok tire, but not as good as Bridgestone Battlax T31 which lasted longer. On my last set of PR3's for another 6000k, then will probably go back to Battlax T31's,
Threads: 5
Likes Given: 34
(07-17-2020, 06:21 AM)SCCBrider_imp Wrote: (07-17-2020, 03:50 AM)E11even_Hunnit_imp Wrote: If you haven't already tried them, might wanna check out the Pirelli Angel GT's in 120/160 sizes. Others here have said good things about them and they are actually on sale right now @ Revzilla(~$250) for a set.
Correct. Those are the prices prior to you using the referenced code that gets you an additional $25 off, per purchase. Meaning that if you purchase them separately, you'd get $25 off per purchase bringing the totals to $117 & $138 for a grand total of $255 a set shipped to CA. I figured other states might come out cheaper to the $250 mark since everything is always somehow more expensive in CA
