Who has adjusted their chain?
At 2,100 miles my chain is finally due for its first adjustment exhibiting slightly more than the 1 1/4" max specified.
So I was wondering if anyone else has had to adjust theirs yet and at what approximate mileage?
I had to do mine at about 1,000 miles. I'm hoping the next adjustment takes place a lot more miles than the 1st one. The last Honda chain bike I had went several thousand miles; like over 5k. But my guess is that others will be telling you that they had to adjust their chain early too.
(06-22-2013, 11:00 AM)The ferret_imp Wrote: At 2,100 miles my chain is finally due for its first adjustment exhibiting slightly more than the 1 1/4" max specified.
I was wondering the same thing, mine was just slightly more than 1 1/4 as well at around 2,200.
I never noticed there aren't any locking nuts either.
The axle nuts lock it down. I adjusted mine today on my second oil change as it was out of spec. But I have over 4200 miles on it in just under 2 months sooo.... Big Grin
Randy was that your first adjustment?
Yes it was.
That begs the question; how often do you apply lube to the chain? I'd wander into the "favorite chain lube" area but that might be too much. Smile
(06-30-2013, 08:55 AM)Rboe_imp Wrote: That begs the question; how often do you apply lube to the chain? I'd wander into the "favorite chain lube" area but that might be too much. Smile
About every 500-600 miles.
500 miles is what I am doing on a hot chain, coating the surfaces that contact the sprockets with overspray on the sides. Don't get it on the rear brakes.
Be careful with the chain adjustment. The book says 1 to 1.4 in. I, at first, took that to read 1-1/4", 1.400" is a little over 1-3/8" (1.375). Thus my chain is in tolerance for now..
Gentlemen,
My chain needed adjusting at my 1st oil change, 638 miles.
Chip
  Adjusted valve clearances. Now it's clicking... Jurlie_imp 29 1,986 08-28-2019, 12:16 PM
  Adjusted my preload today HondaJon_imp 12 905 12-31-2016, 02:37 AM
Last Post: tomas_imp
