Threads: 1
I am one step away from buying a CB 1100 standard because I did not find a DLX model.. but were can I find a Dual exhaust ,, I am in USA, But on line I found a Dual Exhaust for CB 1100 standard bike, can I get this in USA,or were can I find a CB 1100 DLX model in USA.
Thanks
http://www.blackwidowexhausts.co.uk/cb11...-586-p.asp
Threads: 17
The link you found was for the 2003 model which will not work on 2013/2014 CBs.
Try here:
http://www.samurider.com/?cat=260
Don't let the fact that it is in Japan worry you...many forum members around the world have dealt with them.
One warning...most, if not all, 4-into-2 aftermarket dual exhaust systems for the current CB1100 require the removal of your center stand.
...oh, forgot my manners!...welcome to the forum!
Likes Received: 640 in 285 posts
Likes Given: 800
there's one in our classifies I believe.
Threads: 66
Depending on the particular exhaust system, the 2014 DLX center stand may work
Threads: 14
Welcome to the forum and if you have the bucks the DLX exhaust will work on your standard CB1100. Here is a link to my post where I added the DLX exhaust header with aftermarket Over Racing slip on mufflers.
http://cb1100forum.com/forum/showthread....LX+exhaust
If you can find a DLX centerstand, it will fit the standard frame, but you will have to fabricate a way to hook the spring. I have yet to take the time for this step yet, but really don't miss the centerstand.
Good luck with your search for parts. Samurider in Japan also has a couple different 4 into 2 and 4 into 4 full exhaust systems, but they are pricey! I bought my mufflers and other products from Samurider, who has great service and quick shipping to the US.
Threads: 1
(04-21-2016, 08:55 PM)Gumby 1100_imp Wrote: The link you found was for the 2003 model which will not work on 2013/2014 CBs.
Try here:
Thanks for the Welcome...and also the information
(04-21-2016, 08:58 PM)The ferret_imp Wrote: there's one in our classifies I believe.
Thanks Buddy for the information
(04-22-2016, 11:10 AM)Ron in MO_imp Wrote: Welcome to the forum and if you have the bucks the DLX exhaust will work on your standard CB1100. Here is a link to my post where I added the DLX exhaust header with aftermarket Over Racing slip on mufflers.
Thanks for the information
Thanks Sir
