Battery beeping
My battery has died after replacing it with another battery my 2014 cb1100 came with that died out also. I thought the problem was my battery. I'm guessing now that it's my alternator. My issue is now that I hooked up a battery tender to the battery and it's starts beeping. A faint electronic beep. Beeps like three times and continues every couple of seconds. I can't tell if it's coming from the battery but it sounds in that area. Can some one tell me if they know what's going on or what it might be??
Are you sure it is not the charger beeping? If you remove the battery and put it on the charger you can narrow it down pretty fast. Non charging batteries could be a bad battery, a bad rectifier or a bad AC generator (Honda's term). That assumes that all the connections are good and you don't have some big accessory load on all the time Smile
In my limited experience the beeping has come from the battery tender (smarter than I am) and is telling me the battery is shot and won't charge.
Dead battery is a symptom.
Thanks for the replies!
I disconnected my battery from my bike and it read 7volts. I connected the battery straight to the tender and it started to charge fine. Then I connected the tender to my bike and there were no beeps. I reconnected the battery to my bike immediately without full charge and then hooked up the tender. Again it started beeping. I now have the battery disconnected and charging. The beeping was coming from the bike somewhere. I haven't had much time to take the side cover off and see where it's coming from but I will. The battery that I have I bought 4 weeks ago. And the battery loss charge 5 days after I last rode it. I would think it would hold charge longer than 5 days.
Something is definitely amiss. The first thing I would check are the fuses to make sure that none are blown.
(06-24-2016, 11:15 AM)Chuck Bronson_imp Wrote: Thanks for the replies!
The connections on the battery should be checked for tightness. The sound, no idea about that. The bike should have no problem keeping the battery charged once it's back to full voltage. The battery has been seriously discharged; it may not be salvageable but you can try.
Chuck, can you please provide the charger brand and model number? And is the battery a Li-ion battery?
7 volts? The battery is destroyed. You have one or more dead cells. Buy a new battery. It doesn't matter that you just bought it. In fact, since you just bought it, you should probably be able to get a brand new one, free, under warranty. Minimum voltage with no damage is about 12 volts. Zero charge is 10.5. You battery is well beyond death.
Nothing on the bike beeps. It's your charger and your ears playing tricks on you. The human brain is abysmally bad at determining the direction of sound even though we have stereophonic hearing -- we tend to go with whatever our eyes are telling us.
I agree with everything AzBob said above.
Since I last wrote. I have charged my battery fully and it has kept 12v for 2 days without riding. When I would start the bike I checked the voltage to see if my charging system works. And I think it does. Puts out 14v while running. On third day checked battery still good. Went out for a ride and everything fine. I know my battery is supposed to be dead at 7v but so far so good. I know my charger is not making the beeping noise. I still haven't taken off my side covers to further investigate. I'm thinking maybe an alarm that was installed before I bought it used.
How long should a battery last without riding or charging? If there is a short somewhere should it pop the fuse?
  ABS , speedometer and battery Walter 10 816 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,756 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 706 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,188 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 297 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,908 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,299 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Replacement Battery dave 54 4,443 02-04-2023, 12:41 PM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,315 10-18-2022, 01:55 AM
  dead battery louied_imp 62 4,288 10-16-2022, 03:48 AM
