road pilot 3 tire
Does Michelin make a 19 inch road pilot 3 front tire?
Jim, check out [url=http://motorcycle.michelinman.com/US/en/tires/products/pilot-road-3.html]this page. About half way down there's a list of the sizes available for PR3s. If you want a 19 inch on, it probably isn't for the CB1100. However, member have fitted them using the standard size front (110/80) and the slightly wider 160/60 on the rear.
(01-05-2017, 04:17 PM)Cormanus_imp Wrote: Jim, check out [url=http://motorcycle.michelinman.com/US/en/tires/products/pilot-road-3.html]this page. About half way down there's a list of the sizes available for PR3s. If you want a 19 inch on, it probably isn't for the CB1100. However, member have fitted them using the standard size front (110/80) and the slightly wider 160/60 on the rear.
I have gone to spoke wheels front and back on my CB1100. The front wheel is same width but 19" diameter. The rear wheel is still 18" diameter, but 4.25" width instead of 3.75. Will use 160/60 on rear- hoping to use 110/19 on front. Hence the question regarding 19" Road Pilot 3.
Have also lengthened the rear swing arm by 3/4". All this because the stock rear wheel just looked too puny and weak- like the bike was born premature. Going for a bigger bike look.
Obviously I have too much time on my hands Excited
Pictures?
(01-07-2017, 04:39 AM)Cormanus_imp Wrote: Pictures?
Will post when I have it done. Need to find a front tire fist. Also, I fabricated a new chain guard and it is off to the plater right now
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 967 07-18-2018, 06:50 AM
Last Post: SportsterDoc
   michelin pilot road 5 tory_imp 7 577 11-01-2017, 01:20 PM
Last Post: 736cc_imp
  Michelin Pilot Road 3's the party's over... bigsheep_imp 21 1,416 07-26-2017, 10:13 AM
Last Post: bigsheep_imp
  Another tire report on Conti Road Attack 2 CR CA200_imp 9 744 06-02-2016, 03:43 AM
Last Post: Ulvetanna_imp
