Battery Charging
I did that thing where I leave my bike "On" because I was going to come right back outside and ride it somewhere but then got distracted.
It's dead. I've had it on a charger for a couple hours, and it's still less than 25%. Can anyone tell me how long it should it take a battery in a 14 standard CB to charge if on a 0.8A charger?
Sent from my Pixel 2 XL using Tapatalk
That stinks. Assuming it'll still hold a charge, if it has a 12 amp battery I suppose it'd take about 15 hours at 0.8 amps/hr. Or, maybe it's not that simple.
It should be pretty close to that simple. The only caveat is whether or not the battery was completely discharged. Some electrical systems will shut off when the battery voltage gets below a certain level (as will some smart batteries).
I've done this a few times over the decades and using my 1 amp charger, it usually took 10-12 hrs for a full recharge.
Jet, don't rush, let it charge properly, nut just surface charge...
After leaving it for 12+ hours, we're up and running again. I think this was one of those "a watched pot never boils" type of thing.
Thanks for the input.
(09-15-2018, 12:47 AM)jethrofelix_imp Wrote: After leaving it for 12+ hours, we're up and running again. I think this was one of those "a watched pot never boils" type of thing.
Good, but a deep discharged battery may never fully recover.
Be good to monitor battery voltage in the morning.
AGM should be 12.8, with key off.
12.7 something is OK
  ABS , speedometer and battery Walter 10 771 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,471 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 655 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,032 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 272 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,356 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,207 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Replacement Battery dave 54 3,746 02-04-2023, 12:41 PM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,127 10-18-2022, 01:55 AM
  dead battery louied_imp 62 4,151 10-16-2022, 03:48 AM
