Side panels
Can anyone advise if the side panels are common to all models of CB1100’s and if they are interchangable
i guess of the samurider.com page you get too a answere....self i am not sure (look in the right corner of our forum here)
I know the side panels on the 13 and 14 dlx are different (one is triangular, one wraps around the frame) but will interchange. Not sure about the 17 ex panels but Houtman could tell you for sure, he has one of each.
If you whip one off and take a pic Chris, we should be able to see if there are any glaring differences.
What are you thinking of doing?
There are some chrome ones on eBay I was looking at.
Both of mine have tiny cracks around the mounting points which probably means they were overtightened in the past and thinking of replacing
eardyweirdy@me.com' pid='220519' dateline='1539727927']
[/quote]
I just checked to see if the 2017 side panels will fit a 2013 or 2014.
THEY DO NOT ! They look very much the same from the outside but different tabs inside.
(10-16-2018, 09:56 PM)Houtman_imp Wrote: I just checked to see if the 2017 side panels will fit a 2013 or 2014.
+1
  Side-to-side play in throttle grip pechorin75_imp 28 1,701 02-25-2014, 08:56 AM
