Corbin seat fitment question
On the Samurider site there are different seats listed for the redesigned 2017 and later CB1100EXs than for earlier models, but the Corbin website shows the same seat as for the earlier bikes. Has anyone fit a 2017 with a Corbin seat?
Yes , I did and it they fit perfectly !
(02-11-2019, 10:06 PM)Houtman_imp Wrote: Yes , I did and it they fit perfectly !
Thanks Thumbs Up
apex1 - which style were you thinking? Gunfighter solo, or with Lady (/w passenger pillion) ?
+1 ^, might be interested in solo
I've seen other references of the solo, but cannot determine if there are any conflicts with the carrier rack.
Now, solo + carrier rack together has an unusual look - so that is yet another issue.
(02-12-2019, 12:05 AM)GoldOxide_imp Wrote: apex1 - which style were you thinking? Gunfighter solo, or with Lady (/w passenger pillion) ?
I am interested in the Gunfighter and Lady so I can take a passenger. I seem to recall that when some earlier aftermarket seats are mounted on a 2017, they are very snug against the 2017 tank, actually causing some deformation at the nose of the seat. Deformation of the seat foam and cover would not be a problem with a Corbin seat because a Corbin seat has a very stiff fiberglass base, but I really am not wanting to have to cram a Corbin seat onto the bike so that it is pushing very hard against the back of the tank. If it is an issue, it will destroy the paint on the back of the tank even with paint protection film on the tank. If a stock pre-2017 seat won't fit a 2017 bike, I'm having trouble understanding how a Corbin designed for a pre-2017 would fit like a seat Corbin actually designs for a newer bike.
I think I recall some of those 2017 concerns on similar past posts. Agreed - tank paint abrasion/loss due to seat friction is bad enough with the OEM seat. There is no interest to make that issue worse.
I have a 2013 ABS , a 2014 DLX and a 2017 EX ; all with a Corbin seat. Because of being 6 ft I ordered for all these bike the higher version.
They all fit perfectly and if anything there is a slightly larger gap on the 2017 between tank and seat.
On all the tanks I did put a small strip of Snyders painters tape (clear ) to prevent belt buckles or zippers from scratching the tank but that probably is not needed .
"Higher seat option" - thanks for the tip Houtman. Will the higher amount equal or exceed the OEM seat, and would you happen to share by how much? One inch? More? Thanks.
  K&N air filter fitment question nikolus_imp 28 3,613 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Tire & Rim Fitment for 2017 EX 17-CB-002 3 398 06-18-2022, 05:56 AM
  Fork Tube hex head bolt tool fitment ? bflint 8 741 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  2017 Seat Loop Fitment on 2014 vicaphit_imp 1 284 05-10-2019, 01:47 AM
Last Post: HBFL_imp
