Battery Tender
So, will a battery tender completely restore a dead battery on a motorcycle, ATV or a lawn mower? What about a Car? It seems from the manual that it would with some exceptions. This one has not been started in about three weeks.....
It couldn’t hurt to try.
Completely? No. Likely to make it usable? Also no.
But if giving it a try anyway, you'll need an actual battery charger that can push say 10A max. Be sure that if the battery needs water, to fill it with distilled water first. Partially dry cells won't take or deliver charge very well.
Completely discharged/dead battery could* be restored again if it is properly/slowly recharged with low Amps, takes time.
AMG/Gell type, will take less time than wet type
*most likely discharged but not defective, i.e. bad cell.
More factors to the ‘what if’? One could be age of the battery itself, previous care, last used, etc..
It would never hurt to hook to a tender for awhile, but can’t expect miracles with a 5+ year old neglected battery.
I use a tender periodically on an assortment of batteries, not normally plugged in all the time. I’ve had many last a good long time.
  ABS , speedometer and battery Walter 10 748 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,445 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 652 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,025 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 269 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,335 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,198 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Replacement Battery dave 54 3,719 02-04-2023, 12:41 PM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,123 10-18-2022, 01:55 AM
  dead battery louied_imp 62 4,118 10-16-2022, 03:48 AM
