rear spools
Has anybody installed rear spools for use with a PitBull stand?
You do not need rear spools for using the Pit Bull stands , just buy the right stand for the CB 1100.
(01-07-2021, 02:09 AM)ampm7_imp Wrote: Has anybody installed rear spools for use with a PitBull stand?
I don't think there's any way to put spools on the CB1100. You would just have to use the adjustable ones with "L" brackets that fit the swingarm. You might want to consider their forward-handle model that makes it easier for one-man operation. It is height-adjustable, and lets you hold it steadier by the handlebar rather than at the back.
The reason why I ask this is because, being in my late 60's sometimes it is next to impossible to put the bike on the center stand with my bad back and it would be better to lift with the stand which I have (PitBull). But, even though I put the spools on previous sport bikes there doesn't seem to be a way to fit them to the CB. I was just curious if anyone had been successful at installing them with their own design.
BTW, Peking I have the stand but it does not have the the swing arm attachments as the one in your picture. I'll check up on that...
I haven’t seen and couldn’t find any posts about spools. All used the type shown above or some mentioned pins for Pitbull.
This just goes to how I am not observant. My PitBull stand has the rubber pieces to support the swingarm. Thanks guys...
Getting older is not easy , every body wants to get old be nobody wants to BE old.
  New Rear Tire and Rear Brake Pads memphismike_imp 5 518 06-11-2018, 09:35 PM
