Key Wouldn’t Turn On?
I was doing some errands with the 2014 CB1100 today. It’s low miles, just over 5k. After my 1st stop I put the key in, no turn. It would go all the way in, would not turn the ignition on.
I thought I may have to get a ride, only 6 miles from home. After about 5 minutes I got it to turn on. It was like it was against a hard mechanical stop.
My next stop, same thing, after minutes of trying, finally got it.
I have lightly sprayed the keyhole over the years, nothing excessive, somewhat upper end stuff from bike shop.
I got home, rotated my spare key in for now, of course old key worked fine at home too. The old key had a very slight amount of grime on it, can’t see how that would be enough to stop it from turning.
I’ll use the other key for now. Anybody see this problem anywhere? Maybe it’s just me? Thanks.
That usually indicates the steering lock is dragging or stuck. Check it to make sure it's not damaged in any way.
Is that just the front wheel lock? Anti theft?
Wheel lock... When you turn the bars all the way left and push the key extra far in and then left, it locks the bars into a far left turn. The idea is that someone can't roll your bike away so easily.
If you are using that locking mechanism it can sometimes be tricky to turn the key... you might have to jiggle the bars a bit while turning the key to the on position.
I think that is what Randy B. is referring to.
You say you have been spraying the keyhole with some sort of lubricant? If so, it's possible that it has gummed things up, though if you are using something designed for the job it shouldn't give you trouble.
When my key gives me trouble, I have used graphite on it and that sorts it out. You can buy it in a tube or just rub a pencil lead on the key. Then just run the key in and out a few times to spread the stuff around in there.
Anyhow, good luck!
I just used a short squirt of spray lube, very seldom. It was as if a mechanical stop, not just gummed up.
I went & did a re-test with my brand new, spare key. It locks the steering to the left and turns on just fine. My plan is to go with this key for a while, see how things pan out.
(08-15-2021, 10:21 AM)sourdough44_imp Wrote: Is that just the front wheel lock? Anti theft?
There is a pin that comes out of the lock that prohibits the handlebars from being turned and goes into this hole in the frame.
If the pin or the hole is bent or contaminated, it can make turning the key a bit difficult. Also if the bars are laying over hard to one side or the other it will cause the pin to drag in the hole and, again, make it difficult to unlock the ignition.
Thanks, I’ll try a look in that area today. This bike has never had an accident or even fell over. I’m just thinking that pin hopefully stays where it’s supposed to stay.
We had a family car a while back, kept beyond 200k, also had manual door locks. The one key was used exclusively, used a lot in the doors too. Eventually that key wore so it was difficult in either the doors or ignition. I’m not expecting that here with the CB-1100, since it’s newer with a much less used key.
(08-15-2021, 07:39 PM)sourdough44_imp Wrote: Thanks, I’ll try a look in that area today. This bike has never had an accident or even fell over. I’m just thinking that pin hopefully stays where it’s supposed to stay.
Since your spare key is working better, this theory holds water. It doesn't take much wear to make a key fail. Good luck!
It's hard to imagine the key would wear that much with so little miles but if that is the case I'd get another spare made now before this one wears down. That's one of those things you think about doing but then it falls by the wayside until it's too late.
I agree, can’t see how a key would wear that quick. A cycle key isn’t opening doors & the rest either, tank & helmet lock don’t count.
Right now my spare is just fine.
  Bike crank but wouldn't start. zirconxi_imp 67 4,055 04-25-2020, 01:37 AM
Last Post: White Dog_imp
  Bike wouldn't start J.W._imp 12 913 02-13-2016, 10:43 PM
Last Post: redbirds_imp
  Bike wouldn't start today.. bad battery? PowderToastMan_imp 23 1,466 12-30-2014, 08:52 AM
Last Post: rboe
