question re bar risers
I know there are several that fit in the risers with the handlebar riding on top of them. Most of them I've seen are at a minimum an inch high.
Does anyone know of a shim kit that fits between top triple clamp and bottom of stock risers? Perhaps no more than 1/2" high? Of course it would require 1/2" longer bolts to hold the shims and risers to the triple clamp.
I think the extra height would let me rock the bars back slightly more without contacting the fuel tank.
Bob
I think you are talking about some 1/2" thick spacers. I don't think the handlebar clamp main 10mm bolt is removable. I think it is cast into the lower bar clamp making replacement with a longer bolt impossible.
The switches are also pinned to the bars to prevent rotation. I would suggest re-drilling new locating holes rather than cutting the pins off, especially on the throttle side. Also, the ends of the brake and clutch master cylinders may contact the bar if rotated down.
This may work for you.
https://www.twistedthrottle.com/handleba...-sw-motech
(08-20-2019, 02:54 AM)redbirds_imp Wrote: This may work for you.
I'm not sure there is a current answer to my question .... but thanks to both of you for taking a shot at it! Interesting to read that the bolts into the risers are permanently in place.
22mm is about 3/4", would get you close.
I think this is to allow bikes that use normal 22mm or 7/8" (22.1mm) bars to use a 1-1/8" (28mm) fat bars while also raising it about 20mm. It won't work to raise the stock bars.
You could buy a pair of stock clamp tops, flip them over and use with longer bolts. This assumes that the top faces are flat.
My bad, must be getting a bit "fuzzy" headed as I age. Here is the right product.
https://www.twistedthrottle.com/sw-motec...ise-silver
This would raise the bars .59".
Yesterday morning I rode for 3 1/2 hours except for a quick gas stop. I was surprized because I am usually squirming on the seat after 1 1/2 hours.
But on the way home I had an annoying knot between my shoulder blades. I installed a set of GenMar pull-back risers last year to straighten my riding position. So I am wondering if anyone else who installed them has had this problem?
(08-20-2019, 10:08 PM)redbirds_imp Wrote: My bad, must be getting a bit "fuzzy" headed as I age. Here is the right product.
This would have worked, except it didn't appear they had these for the CB1100. Had about every other Honda listed, but unless I overlooked it, don't think the CB11 was one of the choices. But thanks for researching. the 15mm would have been about right!
Bob
According to the specs, the clamping screws spacing is 32-38mm. A quick measurement on my bike shows 32 or 33 spacing. So, they should work?
  Bar risers Mixagon_imp 30 2,393 08-11-2022, 10:43 PM
  risers and shield wiredgeorge_imp 3 373 07-01-2015, 06:46 AM
Last Post: wiredgeorge_imp
  Risers cbfan_imp 3 304 09-28-2013, 10:47 PM
Last Post: Hittheroad_imp
