Brake pad life
With the recent talk of brake pads (thanks Bob), I figured I'd give mine a close look while I had my wheels off for a tire change. I have ~28,600 miles on the original pads and all were pretty thin so I ordered new sets plus caliper bolts for front and rear.
I highly recommend doing the pad swap with the wheels off. It was very easy that way. I hung the front calipers from the fork legs temporarily with the old mounting bolts while working on the pads. The fork was resting on a sturdy wood stand built for that purpose so I didn't have to balance the bike on a jack.
I also slipped the rear axle through the swingarm to help hold the rear assembly in place while the wheel was off.
Anyway, back to the point of the story. :-) When I opened the packaging for the new pads, they were almost as thin as the old ones. I could have easily gotten 60,000 more miles out of the original pads. I went ahead and installed the new ones anyway.
I'd gotten so used to seeing very thick automotive pads that I was sure mine were 90% worn; they were less than 25% worn. Lesson learned. The new pads are very thin compared to automotive parts.
if you had thought to measure the depthof the slot with a tire tread depth gauge you would have known the difference.You can use them up until the slot is gone. I have a new set out on the garage, maybe I will measure them.
BTW I get about 20,000 out of a set of pads and thought I was pretty easy on brakes lol.
It’s funny you should mention this. I just replaced the rear pads on my Bonneville, thinking they were too thin. But, the EBC replacements weren’t much thicker. I replaced them anyway, since I had pulled them out.
I made 20K miles on the front ones but if memory serves me right the rear pads were replaced at around 9K.
I think I'm pretty hard on brakes. But I haven't really worn any out except that pad in the back last week which was toast. It was maybe 1/8 as thick as the one I replaced it with. Pretty much paper thin. Well, thick paper :-)
ok a BRAND NEW REAR PAD measures 5/32 nds of pad material to bottom of wear slot. Total pad measures just a hair over 6/32 nds
[Image: 7bbcbd36e415658d7642aefdf97f319a.jpg]
Book me in for free brake job, please.
I was 200 m away from the US border, almost no traffic, just trucks
Peter , you can come to our house for a brake job , I even give you a brake on the cost of doing this.
Thanks for the measurements. I was using the Mk.I eyeball, which is prone to error. I will note the rear pads appeared thicker than the fronts, which were surprisingly thin.
I have fronts in stock too, if I remember after my grandsons ball game I will measure them as well.
  Yuasa Battery Life dave 28 2,599 04-01-2026, 04:44 AM
  Tire life span olafurarason_imp 37 3,852 01-30-2024, 02:20 AM
  Tire Life Report - Metzeler Z8 Interact Gus_imp 24 1,980 09-23-2021, 04:42 PM
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,702 09-14-2018, 12:35 AM
  Front brake and brake light problem Krupator_imp 8 631 05-31-2016, 10:26 AM
Last Post: Ulvetanna_imp
  Brake light for front brake only? meowguy_imp 13 893 08-24-2013, 09:16 PM
Last Post: meowguy_imp
