Fixing an OEM mirror
I noticed that my right OEM mirror got loose inside the case.
The mirror itself rotates while riding and makes vibration noise.
I cannot figure out how to fix it back. Do you have any ideas?
Weird.
Maybe consider slightly (and carefully) pinching down with wrapped plier pinchers at one or more locations on the mirror frame until the rotation stops?
Obviously use force carefully so not to fracture the glass.
I would stick tiny wooden shims (toothpicks?) in there between the glass and the frame at 12, 4 and 8, and trim to suit. You may or may not want to add a dab of adhesive with them. Try without first, see if it stays.
  Mirror Adjustment Question deltamark 14 1,283 03-12-2022, 03:53 AM
  Quick Mirror Question Aka Tsubasa_imp 8 627 06-25-2017, 07:46 AM
Last Post: Elipten_imp
  Mirror mount mattmcuomo@yahoo.com 5 401 01-04-2016, 10:36 AM
Last Post: Ron in MO_imp
  Mirror/stay PowderToastMan_imp 16 1,063 07-02-2014, 07:16 PM
  mirror gasket crack CB1100dan_imp 3 296 12-29-2013, 09:36 AM
Last Post: The Spaceman_imp
