Threads: 33
Likes Given: 95
I am going to add some small bullet LED's to the engine bars on my 2018EX to increase other road users visibility of me. They will be always on so I don't need a handlebar switch which will save on wiring runs. I will power them off a relay which will be switched from a 12v source only on ignition. I was about to ask the forum for the best location of the switched live but thought I would do some investigating first.
Under the left hand side panel there were two wires marked "switched live for accessories". Well that was quick, thankyou previous owner and/or the dealer! That saved me a load of hassle and is in a good spot for my relay and cable runs. These cables come out of the Honda 4-way Sumitomo block which I take everyone has? I just don't know if these two cables are standard or have been added by someone else, they look factory.
Right, off to by a four way automotive relay with a Diode.
Likes Given: 142
There is a switched accessory connector in the headlight shell and in the location you found.
Threads: 33
Likes Given: 95
(12-23-2020, 09:19 PM)Lord Popgun_imp Wrote: There is a switched accessory connector in the headlight shell and in the location you found.
Excellent! I had previously used a headlight connector in my Africa twin to provide power to extra, non Honda, LED light set and they handily provide an input back on the same connector to illuminate the fog icon in the dash.
Threads: 33
Likes Given: 95
Do you know what current they are rated at and what fused circuit they come off by any chance?
Likes Given: 142
I’ll have to look as I can’t remember. I think its 10amp, but IS shared with something. I’ll look at the wiring diagram shortly.
I’d look now, but I’m still waiting for Santa to bring me a Trail 125. Don’t know why he hasn’t come by
Threads: 33
Likes Given: 95
(12-25-2020, 01:02 AM)Lord Popgun_imp Wrote: I’ll have to look as I can’t remember. I think its 10amp, but IS shared with something. I’ll look at the wiring diagram shortly.
that's going to be great, maybe Santa had to move a few things round in the sleigh to fit it in and he's running late. Cheers, no rush on the info, the day it is an all! Have a great one.
Threads: 45
(12-25-2020, 12:43 AM)Tev62_imp Wrote: (12-23-2020, 09:19 PM)Lord Popgun_imp Wrote: There is a switched accessory connector in the headlight shell and in the location you found.
Since LP is busy by the fireplace waiting for Santa to drop down by the chimney to deliver his new toy, please allow me to give you the required info for the power.
The "option" power is supplied via a 10A "OP" fuse or "K" designation in the Honda wiring.
Inside the headlight bucket the 2-pin dummy connector wire colour is "Black/Brown" for +12v and "Green" for ground and the same colour applies for the 4-Pin Dummy connector behind the left side cover.
Note: The 4-pin connector has 2 other wires; One is for the OBD2 communication wire.
Regards
Alain
Threads: 33
Likes Given: 95
(12-25-2020, 06:24 AM)Alain Lee_imp Wrote: (12-25-2020, 12:43 AM)Tev62_imp Wrote: (12-23-2020, 09:19 PM)Lord Popgun_imp Wrote: There is a switched accessory connector in the headlight shell and in the location you found.
Regards
Alain
Regards
Alain
Alain, you are very kind, much obliged.
Threads: 45
hey LP,
Since you were busy, I already took care of it.
Enjoy your new bike
Regards
Alain
Likes Given: 142
Santa didn’t bring it.
