don't wait 24 months
While doing the fluid change on the front brakes (see "wheel sensors" https://cb1100forum.com/forum/showthread...id337785),
I thought - let's look into the left side reservoir, see how the clutch fluid is doing. With the last change just over 12 months ago, I got really surprised about the mess I found. A darkish kind of soup, when measured with a high water contents.
It is clear that on the clutch side fluids will always suffer and get contaminated faster than in the brake lines. But this bad, it surprised me. No safety risk like a non-working brake, but I cannot imagine it's good for the clutch either.
The 24 months interval (even with low miles) may really be too long.
i change all my brake fluids and clutch fluid in everything i own 1 -2 times yearly i been a mechanic for 18 yeah i see what moisture does to hydraulic systems daily
Interesting. I know I am going to get a lot of negative feedback on this, but I didn't change the brake or clutch fluid on my Honda VFR800 for 17 years, and when I did I couldn't tell the difference. I didn't change the brake fluid on my Toyota truck for 20 years, and when I did I couldn't tell the difference. Maybe the climate has something to do with this?
I am NOT advocating not changing your brake and clutch fluids regularly, and absolutely not waiting for as long as I did. I just keep busy, and if I feel that something doesn't need fixing, then I don't fix it. I haven't changed the brake or clutch fluids on my 2014 CB1100, but it is on my list of things to do.
In case anybody wants to accuse me of neglecting the maintenance on my vehicles, I can assure you that my vehicles are meticulously maintained. My VFR800 has over 117,000 miles, my CB750 has over 120,000 miles, my Toyota has over 241,000 miles, and my VW has over 421,000 miles, and I am the original owner of each.
I just did my clutch reservoir for the first time on my 2014 last month also and i was super surprised how it looked.
Had stuff growing in it almost looked like egg drop soup! The fluid itself was darker but the flush was easy. I removed the dirty cramp from the reservoir first and topped it off with fresh fluid before I flushed. I didnt wanna send that crap down the line.
(07-24-2023, 04:46 AM)Dave_imp Wrote: Interesting. I know I am going to get a lot of negative feedback on this, but I didn't change the brake or clutch fluid on my Honda VFR800 for 17 years, and when I did I couldn't tell the difference. I didn't change the brake fluid on my Toyota truck for 20 years, and when I did I couldn't tell the difference. Maybe the climate has something to do with this?
No negative feedback from my side Wink
I hear you, I tend to believe you. But your VFR is presumably a non-ABS bile. And what I learned the hard way last year (and others seem to have confirmed), the little one-way valves inside an ABS module will cause trouble - long before 17 years later.
If you wipe it clean, then add new ... isn't there a (slightly higher) chance that this way you get air into the system, ... very little but still. If you remove only most of the old fluid, but leave the opening covered that chance is clearly zero.
(07-25-2023, 04:55 AM)m in sc_imp Wrote: one note on changing fluid, and i've done this for over 30 years. get a big syringe, suck the old fluid out, then wipe out the master with a clean paper towel, then add new fluid and flush it though. I can't tell you how many people i have seen push a reservoir of old fluid unnecessarily through a system. .02
Thats how I did it M, can't get air in the system if you dont pull the lever.
Sounds sensible m in sc.
Yep, this is how I do it too.
Must be the right way! Big Grin
  charger: 24x7 - 4 months? HikerToo_imp 7 494 02-08-2019, 04:55 PM
Last Post: alprider
  10,000 mile inspection, at 8 months of service SportsterDoc 14 1,300 07-07-2018, 06:00 AM
Last Post: TCinNC_imp
