Threads: 43
I am looking for the opinion of that guy with a lot of expertise gained in a motorcycle shop.
The repair manual calls for quite a few bolts to be ditched after one time use,
example: mounting bolts on the front brake calipers.
a) what's the rational behind this ?
b) have you done it in your shop, and if you didn't, did this ever cause problems ?
Likes Given: 789
Some bolts are made to stretch for some reason and they lose their uniformity getting longer and skinnier in the middle
Likes Received: 877 in 480 posts
Likes Given: 1,011
I have not been good about replacing the front brake caliper bolts and have not had a problem. For some reason I did change them a week or so ago when I had the wheel off.
Threads: 14
Likes Received: 200 in 93 posts
Likes Given: 221
Torque to yield bolts lose their strength once they stretch. They are designed to be a onetime use as tightening them again to the yield point of the bolt runs a high risk of breaking the bolt. This is very common for cylinder head bolts, however I never heard of caliper bolt being a torque to yield.
Threads: 33
Likes Given: 95
There are also a lot of "single use" bolts just because they come factory coated with a thread locker coating already applied and nothing to do with stretching.
I had to take the engine bolts out of my Triumph Daytona to mount frame sliders. The bolts were reusable but the nuts were one time use only. There was a fair bit of friction to get them torqued up.
Threads: 43
Thanks for your input, all.
Wouldn't a bolt of the stretching kind have a special area (not where the thread is) for stretching. If it changes shape where the thread is ... uhhu ...
What I mean is, wouldn't it be possible to see and identify such kind of bolt ?
@tev : have the feeling that's why the caliper bolts are "one time", at least that would make sense to me.
Threads: 41
Likes Given: 39
Good, correct info above. There are certain single-use bolts, such as connecting rod bolts that should be replaced.
But caliper and disc bolts, like Tev says, have a locking agent applied to the threads from the factory. Honda, with it's typical overabundance of caution and fear of litigation, cannot rely on a mechanic or owner to re-apply it. I would simply apply Picture and reuse and re-torque.
Likes Given: 789
per google:
Bolts that stretch under use are called torque-to-yield (TTY) fasteners or stretch bolts. They are tightened past their elastic limit, causing them to permanently deform and elongate. TTY bolts should never be reused because they become weakened and can't apply the proper clamp load. They must also be replaced if they are loosened or removed, even slightly.
Stretch bolts are designed to stretch when assembled to provide a strong and reliable clamp. They are especially useful in critical assemblies where loose bolts can cause serious problems
Threads: 39
Likes Received: 15 in 8 posts
(10-15-2024, 01:09 AM)pekingduck_imp Wrote: Good, correct info above. There are certain single-use bolts, such as connecting rod bolts that should be replaced.
Same advice here and the internet search also agreed with us.
Out of curiosity i got my torque wrench out and checked the values;
Top right bolt: 26nm to undo and 33nm to put the bolt back on it's mark and similar for the others.
the bolts were just rotated until i could feel movement and placed back on the mark so the
loctite is still servicable.
Over tightening would worry me more because the calipers are aluminum....
So replace with blue loctite is fine, something else i do is to rotate the calipers in the direction of
the brake action just before doing the bolts up, this makes sure that they are always aligned perfectly on the disks and mark the bolts with a yellow crc marker pen along with some other bolts for a quick visual check, thanks Gecko for another good question, hope we cleared this one up.
Threads: 13
Thread locker around the brakes might be "special" for high temperatures. So there's that.
IMHO: If the bolt we are talking about is for a floating caliper, it's not stretchd ot fatigued as an engine head bolt would. Just make sure the shank is clean and without marks or scratches that could hinder caliper to float, and make sure that proper thread locker is used. If we are talking about the caliper carrier bolts, the heat they receive is much less, so they don't suffer cyclic loading. But my bike has radial calipers (RS) so I don't know exaclty how the floating caliper assembly is done.
I agree with pekingduck when he mentions "Honda's typical overabundance of caution and fear of litigation". I would trust resuing those bolts, but I'd be checking periodically that they are not coming loose (just use a marker and check they don't rotate). Maybe use loctite 272, or some other high-temp threadlocker (although it might be dificult to remove in the future...)
