Tamper proof oil filler cap
Hi all Is there one of these available for the CB1100? If not does anyone know if the BMW one would fit the Honda? (most likely different thread/hole size)
https://www.aliexpress.com/item/32885619..._ext_f=%7B"sku_id"%3A"65648193259"%7D&pdp_npi=2%40dis%21GBP%21%217.31%21%21%21%21%21%402100bdec16574534786367207e8​71d%2165648193259%21sea
(07-09-2022, 09:50 PM)Maturecheese_imp Wrote: Hi all Is there one of these available for the CB1100? If not does anyone know if the BMW one would fit the Honda? (most likely different thread/hole size)
Good question, and nice find MC.
The tamper-resistant filler cap is also good lookin'.
[url=https://www.aliexpress.com/item/32885619543.html?spm=a2g0o.productlist.0.0.2f095625JvDQsc&algo_pvid=9b8c1ca0-4fef-4395-afef-c135ef2f63ef&algo_exp_id=9b8c1ca0-4fef-4395-afef-c135ef2f63ef-18&pdp_ext_f=%7B]
(click on image)
They look nice. They are just a torx though- tamper ones would have a nub in the center.
I'd suggest silver as the anodizing would mar where the tool rubs.
Looks nice, but is oil tampering a thing?
I was wondering the same thing tommymck
If someone has a BMW that these fit, it would be easy enough to see if they fit the CB1100 before you order any.
(07-10-2022, 01:53 AM)The ferret_imp Wrote: I was wondering the same thing tommymck
... probably easier to quickly punch a gashing hole in the side of the engine case.
If I recall, the BMW has a larger diameter hole than we do. My old R1200R had a factory tamper-proof oil cap. It had a funky triangular shape to it, which required a supplied tool to open.
My 2004 BMW R1150RT has a completely different cap. It is all plastic, but is not threaded at all. Inside is a plastic T which fits into a slot inside the case. Nothing threads into anything.
How about tamper-proof valve stems? Or tamper-proof throttle cables? Or spark plug caps? Axle bolts? Rubber hoses? Bleeder screws? There are too many exposed components on a motorbike to worry about that could be tampered with that would leave you stranded, or dead.
Sobering thought.
  Warm ‘Crack Filler’ a Hazard Riding? widude 17 1,329 07-09-2020, 11:27 PM
Last Post: Rocky_imp
