Salvage Parts
My 2013 went to salvage and was auctioned off by Copart in Newburg NY in August. Don't suppose any of you bought it?
My replacement 2013 has the high idle issue, but the salvaged bike ran great. I missed my chance to buy the old one back for parts like the ECU IACV. Do any of you know where to look for used parts?
There is a 2014 in RI with a day of bidding left. Current bid is only $30: https://www.copart.com/lot/57286482/salv...-ri-exeter
If I wasn’t living on the other coast, I would pay twice that much.
Tom, start with the ECU, if you can find one. I'd send you mine, but I had the high idle problem until I removed it, so you probably wouldn't find it much use. I can send you my old IACV because it looks really good and I don't think it was the cause of the high idle, since replacing it didn't fix the high idle problem. No charge, I just don't need them.
(10-05-2022, 04:33 AM)Nachodaddy_imp Wrote: Tom, start with the ECU, if you can find one. I'd send you mine, but I had the high idle problem until I removed it, so you probably wouldn't find it much use. I can send you my old IACV because it looks really good and I don't think it was the cause of the high idle, since replacing it didn't fix the high idle problem. No charge, I just don't need them.
That's a very nice offer. I'll message you. Thanks.
Man, I wish I had seen this sooner; I'm only ~25 minutes from that yard. I would've parted out whatever folks need...
  Salvage bikes available Tom_imp 1 232 10-27-2022, 12:47 AM
Last Post: ymtnpoah11_imp
  HONDA using parts from older parts bin 17-CB-002 4 523 07-27-2020, 04:17 AM
  2014 CB1100 Salvage title Honda_Fan_imp 38 2,412 01-29-2019, 02:28 PM
Last Post: rboe
  Parts sources for used CB1100 parts. FLYTYM_imp 2 310 10-30-2018, 07:56 AM
Last Post: tinboatcapt_imp
  Parts bike? CB1100 at salvage auction 4 Paws_imp 0 170 03-29-2016, 01:12 AM
Last Post: 4 Paws_imp
