"Where" is the extra fuel capacity?
I have a '13 Standard. My "eye" isn't good enough to see where Honda added capacity to the larger tanks. Taller? Wider? Longer?
Are seats on any models interchangeable or does it depend on which tank you have?
(03-31-2015, 01:03 AM)Olyrider_imp Wrote: I have a '13 Standard. My "eye" isn't good enough to see where Honda added capacity to the larger tanks. Taller? Wider? Longer?
The 2014 DLX tank is noticeably higher in back. I think the new Standard has the same capacity as the 2013.
Yes a barely discernible hump at the top rear from mid tank back to the seat... and the knee indents are shaped differently, not that that would add any capacity, just a design feature.
  2016 Canadian "Special Edition" black with checker flag? jdixon1974_imp 9 742 04-08-2024, 03:17 PM
  Would the CB been more of a "success" if there had been more ABS bikes? RockHop_imp 40 2,870 01-15-2024, 12:42 PM
  "Internal Server Error" Nachodaddy 16 1,197 06-23-2023, 06:35 AM
  Using the new Apple "AirTag" to locate your motorcycle in case it is stolen 17-CB-002 31 2,357 02-24-2023, 08:30 PM
Last Post: emptysea
  How many extra watts of accessories can the CB1100 handle? HondaFan_imp 13 1,147 05-23-2021, 11:28 PM
  How Honda manufacture the 2017 "Flangeless Tank" 17-CB-002 5 547 12-22-2020, 12:03 AM
  Seat height for 5'9" around 30" inseam? Gilstrak_imp 31 2,229 09-17-2020, 08:33 AM
  "it was a bad day" .. Chuckk_imp 24 3,109 02-13-2020, 07:04 AM
Last Post: Chuckk_imp
  When Bike Bandit ships you a 17" tire instead of an 18" zbillster_imp 30 2,069 07-26-2019, 06:04 AM
Last Post: JLEECB
  Conversion to 19" front rim LongRanger_imp 20 1,443 04-04-2019, 01:24 PM
