8K service
Oil changed, bike washed, waxed, changed to metalmaven's license bracket, and new brake pads today. It's looking like a nice weekend to get out and ride up here.
[Image: e5b43df9e4f3bd9292ba5ee09ee41cf5.jpg]
[Image: 2665801aeb1c8f76e26021bad16968dd.jpg]
[Image: 95c431ee75c2ce39df9ec7fc20d00538.jpg]
No valve check?
Looking good. Enjoy the ride this weekend. Did your brake pads actually need to be replaced or did you just choose to replace them?
Curious about that too. I have 12k miles and lots of pad left.
I bought the bike used and the rear pads were a bit thin and worn unevenly. I think the guy before me rode the rear brake. Fronts look great still. The rear caliper also has some play that I don't like. Not sure if that is normal yet.
I would have done a valve check but don't have any information on what needs to be done yet. I need to look that up still.
According to the service manual, at 8,000 miles, the following should be done:
Inspect: fuel line, throttle operation, valve clearance, engine idle speed, secondary air supply system, drive chain slider, brake fluid, brake pad wear, brake system, brake light switch, headlight aim, clutch system, clutch fluid, side stand, suspension, nuts/bolts/fasteners, wheels/tires, and steering head bearings
Clean: crankcase breather
Replace: spark plugs, engine oil, engine oil filter
Of all those inspections, checking valve clearances will prove to be the most labor intensive. I haven't done a search on the forum but know there are some high mileage CBs here and I don't recall reading about any of them being out of spec. Still, I plan to at least check mine when the time comes and, if any adjustments are needed, I hope to have the courage to do it myself.
Also, replacing the spark plugs at 8K miles seems a bit early to me. I'll probably just check mine and wait until 16K miles before replacing them.
Over 12k miles on #95 and have yet to crack it open for anything other than oil and filter.
(06-07-2015, 04:45 AM)Motogeezer1949_imp Wrote: Over 12k miles on #95 and have yet to crack it open for anything other than oil and filter.
Ditto....will turn over 13K in the next day or two
  Honda Service Manual?? PJV_imp 45 3,470 08-21-2025, 10:51 AM
Last Post: michael1954
  CB1100 service manual jdvalero_imp 26 2,340 08-21-2025, 04:07 AM
Last Post: DavidFS
  Service Manual tomcat_imp 13 1,117 08-08-2024, 11:13 PM
  Picked up my 'official' Service Manual ohiorider_imp 8 611 07-18-2019, 08:23 AM
  Just got my 2013 service manual 562loosenoodle_imp 12 939 02-17-2019, 08:18 AM
  75,000 mile service Haystack_imp 22 1,505 01-07-2018, 02:10 AM
Last Post: ohiorider_imp
  Digital Service Manual tuareg 3 276 11-12-2017, 02:18 AM
Last Post: Nortoon_imp
  Time and branch of service Obleo 36 1,923 07-03-2017, 08:27 AM
Last Post: TINK_imp
  Service contracts are they worth it on a new 2017 cb pittycheria_imp 14 767 05-23-2017, 05:41 AM
Last Post: EarsOnWheels_imp
  8k service in NJ/NY elemenopi_imp 8 506 09-18-2016, 08:56 PM
Last Post: CIP57_imp
