exhaust baffle
Is there a baffle that be removed in the ugly exhaust can? Need a little more note to drown my valve tapping. I most likely will end up putting something else on it but for now I'm too busy riding!
Been covered a couple times, with at least one member completely gutting his stock can. For a little more sound, I removed the end cap of the stock can and drilled 3 half inch holes around the center pipe in the rear baffle. This adds a small amount of added "growl" to the exhaust tone. An aftermarket exhaust is the only way to get a truly louder tone.
Sent from an undisclosed location
Probably not valve tapping you are hearing but fuel injectors clicking. Soon you will not pay any attention to them.
Good info, I though the tapping/clicking was valves. I have 425 miles and was going to address the noise at the first service, next Monday. I ride it every day to work, 25 to 30 miles. By Monday I should have my 600 miles.
Thanks...
Thanks soldier. I'll take the cap off tomorrow and take a look.
Huh, fuel injectors...who knew? Guess I have a lot to learn about FI bikes. Never knew they made a sound.
My Triumph had a ton of valve noise until I put megaphones on it. Haven't heard 'em since.
http://cb1100forum.com/forum/showthread....ht=Gutting
Look at posts 13, 17 and 18 to see what you are up against
Thank you sir
(09-14-2015, 09:30 AM)WhiskeyUSMC1979_imp Wrote: Been covered a couple times, with at least one member completely gutting his stock can. For a little more sound, I removed the end cap of the stock can and drilled 3 half inch holes around the center pipe in the rear baffle. This adds a small amount of added "growl" to the exhaust tone. An aftermarket exhaust is the only way to get a truly louder tone.
Did this change the back pressure and did it require any remapping to avoid popping?
I did nothing to the bike other then drill a few holes.
So I went out this morning to drill some holes...my drill had crapped the bed.
Guess I'll live with the tapping for now.
