Threads: 43
The last half mile towards my house is a gentle, flat, bump-less piece of tarmac. For years I am used to accelerating to 45 mph after the last intersection, switch to neutral and role right into my garage without power ... in my car. Speed “on final” has been adjusted to a “perfect” 36 mph passing a traffic sign, all I have to do is push the remote for the garage door. Sometimes I turn the ignition off right after the sign.
Now I tried this a few times on my CB. Guess what, she does not even get close to the garage. Not at 36, not at 40, barely at 45.
How do you explain this taken into account :
- my brake pads and disks show no unusual signs of wear
- gas mileage on the CB is an average 50 and seems good
- my gas consumption in the car is about 25% higher
- gross weight is 5 times the bike
- bike’s tires are good (not new or worn)
Where is this friction on the bike coming from ? Why does it not decrease gas mileage?
Thanks for helping with the puzzle.
... yes, much less inertia storage in the CB1100 compared to a cage.
Threads: 10
Likes Received: 178 in 103 posts
Likes Given: 474
You obviously need to gain some weight.
Threads: 245
Likes Received: 1,187 in 509 posts
Likes Given: 966
1/2 a mile? When I'm coming home really late and don't want to wake the neighbors, I'll kill the engine and try to coast to my garage. That's proabably a bit less than 100 yards and I can't coast the entire way.
(06-28-2023, 02:33 AM)Nachodaddy_imp Wrote: You obviously need to gain some weight.
Oh my, lol!
Threads: 43
(06-28-2023, 02:51 AM)Gone in 60_imp Wrote: 1/2 a mile? When I'm coming home really late and don't want to wake the neighbors, I'll kill the engine and try to coast to my garage. That's proabably a bit less than 100 yards and I can't coast the entire way.
Admitted, my 1/2 mile is more like 1/4 mile ...
(06-28-2023, 02:10 AM)m in sc_imp Wrote: the car has a lot more mass therefore will coast longer @ same speed. just basic physics.
okay, back to basics,
energy e=mv^2, so much more in the car,
but that ain’t what matters, remember two stones (big and small) falling from a tower arrive at the same time at the ground because the acceleration is the same. What matters here is the deceleration (negative acceleration) d equal some factor for the friction times the speed (not the mass or energy’), so it comes to d = f x v.
If the friction in the tires, wheels, bearings, drag .... etc was the same, car and bike would decelerate the same way.
Therefore the question ... can the slick bike, with two small tires, and light weight slow down faster ?
Nacho, if you knew my “figure” you would understand that any extra pound at any part of my frame would be a sin !
Likes Received: 587 in 321 posts
Likes Given: 991
I am not a physicist or engineer, but I think due to tires width, tread, size, construction and number of tires(4), a car has less rolling resistance, meaning less weight per sq inch.
A lot of cars are equipped with low rolling resistance tires to achieve a better fuel economy.
Never heard about a moto tire, maybe there are??
Threads: 34
Likes Given: 9
Only because I like pedantic arguments like this, I'll "weigh" in.
The simplest way to think about it is in terms of deceleration. Since both the motorcycle and the car start out at the same velocity, if the motorcycle travels less distance, it's because it decelerated to zero quicker. Why would that be? Since F=m*a, a=F/M where F is frictional and aerodynamic force in the rearward direction. If that force were identical between the car and the motorcycle, clearly the motorcycle would decelerate quicker since its mass is less.
The frictional and aerodynamic force for the car is certainly going to be more than for a motorcycle of course, but not enough in comparison with the mass difference. So the car takes longer to decelerate to zero. Same holds true for m-in-sc's train example.
There are certainly examples though of vehicles that weigh more, but travel shorter distances from speed than some other vehicle that weighs less. For most wheeled vehicles though, the heavier ones will decelerate more slowly due to frictional and drag forces.
People, already posted - inertial storage.
Think: Freight train stoppage.
There is a whole lotta friction during the best of times without asserting the brakes. Look how long they take to stop these not-so-light long bricks-in-the-wind even with ALL brakes asserted (a very long distance).
Threads: 34
Likes Given: 9
(06-28-2023, 07:55 AM)GoldOxide_imp Wrote: People, already posted - inertial storage.
Well, yes in that case....but if you had a "bike" with skinny hard wheels and you disconnected the chain, and you towed it up to 40 mph, it would potentially go as far or farther than a car if you reduced friction enough. The main point is it's the relative ratio of friction and mass. A hockey puck on ice may travel farther than a car coasting on ice given the same starting speed (see...I brought it down to a level that you Canadians can grok  )
