Shifts corresponding to RPM's my experience/your experience
I'd like to get some feedback from my CB1100 Forum Compadres. First, my experience: When I ride my bike, I tend to shift around 2,500-2,800 RPM's...Meaning, for example when I shift from 3rd to 4th I'm generally at around there. I tend to do it by feel...I sort of sense the bike wants the relief it gets by upshifting, plus I'm generally moving faster so it all seems to make sense and feel right. So why am I asking? It's because I'm always hearing about red-line this and high RPM's that, yet I rarely get my RPM's above about 3,300. I do not mean to sound naïve, but am I doing something wrong? Should I be running 6,000 RPM's in 5th gear? Educate me!
Just my 2 cents but that's pretty much the way I drive mine too. OK, there are times when I wind it out a bit. But hey.
modmaster
here's my opinion which I just typed today in another thread
I'm probably one of the more conservative riders on the board. For the most part my bike lives in the 45-60 mph zone, and a lot of that, even at 45 mph, is in 6 th gear (between 2500 and 3500 rpms). My normal shift point is around 3000-3200 rpms, and my bike has never been over 5000 rpms, and never anywhere near redline ..... but there is no problem running this engine to redline, either occasionally, or all the time for that matter. Engines are designed to run within a certain " range " and the range on this bike is from 2500-8000 rpms. It's ok to run this bike in any gear between those rpms (although it is electronically rpm limited in certain gears meaning you will not be able to run it at 8000 rpms in certain gears) but other than that, it will not harm this motor to run it anywhere between those rpms and it's not " better" for it to run it at any given rpm than another rpm in that range
BTW that's how I ride my ST 1300 too
Those are some low shift points, boys! I tend to short shift the CB in the lower gears, as well, usually around 3500 rpm, as I'm very sensitive to the tingling vibration that comes on around 4K RPM. In more spirited riding in the twisties , I'll rev out more. I've had the bike up to the redline, but over 7 k, it's not really doing all that much except making a nice sound. I don't enjoy the short shifting mode of propulsion, but it does seem to be the most appropriate way the utilize the CB's abundant and flexible power band.
If i'm in the city. I'm usually going between 40-70kph and usually in second gear for that entire speed range at around 3200-4000 rpm. I mostly do this to actually have some roll-on power in case I need to escape a traffic situation, where braking won't work (e.g., blind-spot look/swerve). I usually run to redline when merging on the highway, just for fun and then click up to 5th to cruise.
I don't find that revving this bike out (within reason) really effects the gas mileage that much, and I still average around 54mpg on most long highway trips. One of my favourite things about adding the full exhaust and intake mods isn't so much the horsepower increase, but how much more free-revving the engine is, especially at the top end -- makes the engine much more flexible and fun to wring up and down.
(04-12-2016, 08:09 AM)Capo_imp Wrote: Those are some low shift points, boys! I tend to short shift the CB in the lower gears, as well, usually around 3500 rpm, as I'm very sensitive to the tingling vibration that comes on around 4K RPM. In more spirited riding in the twisties , I'll rev out more. I've had the bike up to the redline, but over 7 k, it's not really doing all that much except making a nice sound. I don't enjoy the short shifting mode of propulsion, but it does seem to be the most appropriate way the utilize the CB's abundant and flexible power band.
That's about my style. If I'm just cruising on the straight I'm happy with the 100kph/3400rpm combo but I don't like the rpm dropping below that for any period of time. Similar to Capo, in the twisties I keep a minimum of 4000rpm. I like the engine braking above this and any vibration is of no concern to me.
(04-12-2016, 08:22 AM)kmoney_imp Wrote: If i'm in the city. I'm usually going between 40-70kph and usually in second gear for that entire speed range at around 3200-4000 rpm. I mostly do this to actually have some roll-on power in case I need to escape a traffic situation, where braking won't work (e.g., blind-spot look/swerve). I usually run to redline when merging on the highway, just for fun and then click up to 5th to cruise.
kmoney, how do you measure mpg in Canada? US or Imperial gallons?
I was told by a mechanic friend of mine that you should ride/drive as you expect your bike to perform.. Basically if you short shift all the time, that's fine.. However, if you short shift all the time and once in a great moon, you decide to wring it out, it might be fine but it might not perform as you expect.. Machines show wear on how they are used, if you exceed what it expects on a regular basis.....
Following this idea.. I try to vary how any vehicle is run. Around town will I short shift or take it easy.. However, when I have the opportunity I will wind it out, just to balance things out (Staintune makes this easy, love the new sounds)
We use L/100KMS or imperial gallons, so my figure above would be around 46 MPG in US gallons.
oooooo! just what i've been thinking about all day today while riding. 100 mile day. mine was the other thread The Ferret was referencing in which i posted a picture of the user manual's description of shift points.
(04-12-2016, 06:50 AM)glenridgerich_imp Wrote: I'd like to get some feedback from my CB1100 Forum Compadres. First, my experience: When I ride my bike, I tend to shift around 2,500-2,800 RPM's...Meaning, for example when I shift from 3rd to 4th I'm generally at around there. I tend to do it by feel...I sort of sense the bike wants the relief it gets by upshifting, plus I'm generally moving faster so it all seems to make sense and feel right. So why am I asking? It's because I'm always hearing about red-line this and high RPM's that, yet I rarely get my RPM's above about 3,300. I do not mean to sound naïve, but am I doing something wrong? Should I be running 6,000 RPM's in 5th gear? Educate me!
my feelings exactly! i want to feel the power bands and shift according what the situation dictates. which for me tends to be in the 5000 range? maybe 6's? but as i stated in the other thread, that's what i'm used to and it may not be the better way to ride this machine. today was spent trying to get that little mpg dealie to go up in numbers. i don't think i ever got above 4000rpm. and man did that feel weird! not right for me. but i wanted to see if i can hit all of these fantastical numbers i keep seeing posted. like 60 mpg! posted by a rider who kept it under 4000 to do so. i got it up to 46 and i guess it'll keep changing until i finish the tank.
(04-12-2016, 08:45 AM)Hondahawkrider_imp Wrote: I was told by a mechanic friend of mine that you should ride/drive as you expect your bike to perform.. Basically if you short shift all the time, that's fine.. However, if you short shift all the time and once in a great moon, you decide to wring it out, it might be fine but it might not perform as you expect.. Machines show wear on how they are used, if you exceed what it expects on a regular basis.....
HHHMMM, sounds somewhat like what i've heard about, he he he, "blowing the crud out" eh Ferret? Wink so, if i putt around all day short shifting and playing mini-golf, my motor won't be as happy compared to winding it out on a regular basis?...Facinating
-Kirk Out
  Timbersled experience? Offroad 4 435 03-01-2018, 11:01 AM
Last Post: LongRanger_imp
  First Long Ride (Naperville IL - Bloomington IL) Experience.... Nano Tech_imp 9 780 07-03-2013, 03:02 AM
Last Post: Nano Tech_imp
