Bolt won't budge
So I have been trying to install OEM crash guards on my 2017. The bolt on the frame will not budge. This is the second one down (black bolt) on the frame. Dumb question, it's counter clockwise for loosen right ?!! - any ideas how I can open this bolt. It's a 14mm , I am using a socket and ratchet.
Successfully completed by 600 mile oil change , super easy.
(07-03-2017, 09:39 AM)pittycheria_imp Wrote: So I have been trying to install OEM crash guards on my 2017. The bolt on the frame will not budge. This is the second one down (black bolt) on the frame. Dumb question, it's counter clockwise for loosen right ?!! - any ideas how I can open this bolt. It's a 14mm , I am using a socket and ratchet.
Loosen the nut first
Whack it with a hammer, that'll usually work. It's probably got Loctite on it.
I would recommend an air or electric impact wrench.
Shows what a dufus I am , had to loosen nut first !- thank you houtman[Image: 7f0e586f01b4bb89b8d6145f589bb48c.png][Image: 19e0477676053ab14408b3722694d42b.png]
I did the same thing installing mine. I'm a member of the club too.
2014 Honda CB1100 DLX
2002 Honda CB750 Nighthawk
The bolt has the torque of the nut plus the weight of the engine, plus friction in the misaligned holes stopping it from turning. Loosening the nut helps remove two of the three forces.
(07-05-2017, 04:58 AM)kennyw_imp Wrote: The bolt has the torque of the nut plus the weight of the engine, plus friction in the misaligned holes stopping it from turning. Loosening the nut helps remove two of the three forces.
Thanks makes sense and brings memories of physics class !
  Looking for a bolt size FLYTYM_imp 3 394 01-07-2021, 08:02 AM
Last Post: Rocky_imp
