Side kickstand question
I’m installing a heel/toe shifter (because I have left drop foot). To make it fit I need to cut off this metal loop. Does anyone know what its purpose is?
So you can kick the side stand out otherwise its up tight against the bottom of the bike
I use it to engage bike’s side stand without looking at it while on my bike, don’t think there’s any other purpose..?
Yeah, it’s what Ferret said.
Can you heat it and bend it back (down) to gain clearance?
(09-15-2024, 04:37 AM)The ferret_imp Wrote: So you can kick the side stand out otherwise its up tight against the bottom of the bike
Thanks
(09-15-2024, 05:28 AM)Karidis_imp Wrote: Can you heat it and bend it back (down) to gain clearance?
Thanks
Good idea, I’ll give that a try before I cut it off
I think if you can line it up to sit underneath the shifter pivot you might get it to work.
Thumbs up emoji.
(09-15-2024, 08:28 AM)Karidis_imp Wrote: I think if you can line it up to sit underneath the shifter pivot you might get it to work.
  U.S.-spec 2017 CB1100 EX side cover question VLJ_imp 25 1,536 11-04-2018, 12:19 AM
Last Post: VLJ_imp
