First Ride observations
It is so smoo.......th I had to look at the speedo and gear indicator once in a while. Quiet.
Only my first 100 miles so my feelings about stuff may change.
The mirrors don't do it for me. I only see about 60% out of them. I might have another go at adjusting them.
Would have liked a bit more room between the shifter and foot peg
I really had to angle my foot down to get under it. I started a bad habit of just shifting with the side of my boot.
Seat started to get a little hard/not so comfy. Might spring for a sheepskin or a foam pad. Ya'll with corbins - Like/ no like?
I like the power. Its not crazy but there is plenty there for my sensibilities.
the little samurider fairing works great. wind but no buffeting. I was pleasantly surprised by this.
There are a few muscles that got a bit more action than they usually get.. I'm kinda sore/felt like I worked it today.
I need some foot pegs to attach to my sw motech engine guards so I can stretch out now and then.
It was cooler than I've ridden on a naked bike in a long time.
Heated grips/liners/vest are definitely in the offing.
I better get used to it... I sold my 83 Goldwing today.
I find that I can only be comfortable in shoes with thin soles, I need that room to fit under the shifter.
Like your sig says, It is what it is.
(03-31-2018, 03:13 PM)dbarkdoll_imp Wrote: Like your sig says, It is what it is.
Yeah, but it may depend on what the meaning of is is. Big Grin
I like it. I'll probably do a few things to dial it in but I think its gonna do what I want it to do.
I like my Corbin seat and it seems to be the only option if you want a sissy bar at this point (my wife won't ride without it). Although you have a top box so maybe it has a pad on it.
I picked up a used Daytona seat this winter at the suggestion of forum member rdtwohig who swears it is better than the Corbin but I haven't tested it yet other than sitting on it.
You can adjust your shifter up. I did it to mine as I had the same issue with it being set too low. Take a look at the shifter linkage and you'll see that it can be adjusted.
Yeah, I had to adjust mine too.
I had the opposite issue. I needed to lower my brake pedal.
Thanks I will have a look at the adjuster.
If that don't do it...
I was wondering if there is a longer shifter that honda makes that would fit over the splines.
There is quite a bit of adjustement in that adjuster, plus you can move the shifter on the spline itself.
  Some observations on the 2017 EX ..some pics added the Ferret 44 2,584 06-24-2017, 01:39 PM
Last Post: Elipten_imp
