Heads up for anyone considering getting a Dynojet Power Commander
Dynojet has discontinued the Power Commander 5 / PCV and released the Power Commander 6.
The only difference is that the 6 is limited to +/- 15% fueling adjustment of the base map that Dynojet supplies.
This is because of EPA pressure. This is for all bikes.
For most people- this won't matter.
But for those wanting to actually do something beyond an exhaust, etc- you will need to go to a Dynojet dyno tuning center to pay them to tune further than 15%.
how long before they change the tuning software ...
The change has already happened – the software knows what module is plugged into it. They can’t retroactively go back and limit the power commander five or else they would have outrage and lawsuits.
Spent over an hour on the phone with a guy from Dynojet yesterday.
While we were working on other things, I mentioned the 5 VS 6 and he said the only difference was the amount of adjusting +/- but when I followed that up mentioning EPA- he said that was a part of it but also- by allowing the wider range of adjustment they had previously they were getting a lot of calls and time spent on things that were people putting in adjustments outside of where they should.
So they picked an adjustment range that suited the vast majority of users and set it there. A Dynojet shop can move the settings beyond that if needed.
If I remember correctly, and that is no longer guaranteed, that unit is the four-pot adjuster? I put one on my Kawi Vulcan 1500 bagger to stop a very bad ping. It worked great, and with a modded exhaust turned that clunky slow-poke into a sporting touring machine.
No, this is all done by laptop, no pots.
The last one I know with pot was the power commander three and they are on power commander six now.
My father-in-law has a Vulcan nomad with a power commander three and aftermarket intake and exhaust. But I think they also have a power commander five for his bike. I will have to double check because if they do it would be fine to upgrade it and return it and see what the differences are.
I created an account here just to post on the PC6.. May save you some headaches. First off if you can find a used PC3 or 5 - 100% get it.. Dynojet changed the 6 to force you to pay their certified tuners if you want/need anything more than the mist basic tuning usually to get rideif lean pops out when you add unrestricted exhaust
Here’s the short list:
* PC6 has an end user max change capped at +/- 15% over stock ECU signal for fuel and +/- 5 deg timing (if applicable to the model your bike uses or if you add their timing module). These are arbitrary % based changes not actual values like degrees of advance...
* PC6 Does Not Display the Real Values in the Tuning Map becuase there are 2 maps for each acrual map, a base map that you can’t see and the map that has your changes... It comes with a base Map for your bike model.. Now Imagine adding 5 degrees timing only to find out there’s +3 in their base map but the Ignition Tuning Map shows 0 degrees.. You just bought a new engine and no there is NO Warning in the User Interface and until recently there was NO Documentation in the Manual or their Website..
*PC6 AutoTune.. “AutoTune” is a stretch. It records the required differences in fueling to meet your target AFR values by recording the actual AFR and then storing the required fuel map changes needed to meet that target value. It *will* also insert some wildly inappropriate values so you have to check and smooth the maps after “accepting” the changes. Expect to repeat this process at least 7-10 times and review each change to establish a half decent base tune. Make sure you Disable Autotune once you have a desired tune and I’d def reccomend removing the wideband O2 sensor(s) at this point as well as they typically only survive a yr. It won’t tell you if the sensor data is bad it will just provide bad values. It will only tell you if the sensor has completely failed by not loading it in the PC interface and showing a red light on the autotune module but while riding you have no way to know.
Maps:
* PC6 has a *Tiny* fraction of the maps available for PC5, Dynojet could Easy Convert PC5 maps to 6 without needing the specific bike to do so.. but choose not to.. Dynojet intentionally did not announce this difference when the PC6 was released, not in the manual or their website.. Why Help Riders when you can Extort them ?
* PC6 You *CANNOT use a Map from someone else* since you Cannot Verify what the Map Values are without risking your engine. PC5 has tons of community built maps that are widely used and in many cases Dyno verified. Dynojet shut this down completely with PC6…. Again its much easier to make money if the community is blind.. Consider there is no decent aftermarket Car ECU that does this.. Only Dynojet
* PC6 does not use the same map editor as PC5, it uses PowerCore which has specific licensing that hides PC6 features from end users.. Only Dynojet Tuning Centers can access the same things you can in a PC5
* PC6 Maps are in the “XXXXX-XX” format PCV maps are “XX-XXX-XXX”
* 18031-01 is a PC6 map for example
* PC6 Map Switching Actually Does Work and maybe the Best Feature of the 6 they didn’t Ruin
* PC6 Cold Idle Control also works very well, you can easily set a cold idle (rpm) and duration of Warmup
* PC6 Launch control - supposedly this works, I havent tried it yet
* PC6 Removes the Accelerator Pump Feature (used to add extra gas upon immediate throttle up - it’s a Digital version of what carbs do when you hit the gas). This allowed you to smooth out the instant response and is particularly useful smoothing response when low-speed maneuvering and on some of the more twitchy bikes. Again onlylicensed tuners can accss this...
I bought a PC6 early before Dynojet got exposed for these shady changes and none of it was in the manual or website... They did not and still don’t have a suitable PC6 map for my bike.. despite promises etc.. I’ve had several aftermarket ECU’s and piggybacks in cars over the years but none were a scam like what Dynojet has pulled in the 6... Removing core function, hiding the actual tuning maps, forcing you to pay more for same features in the previous model, restricting rangea of change and falsey advertising initially.. It should cost 1/2 for what they removed..
If you want to only tune out popping, have 2 maps and idle control it will do it but its seat of the pants tuning. I highly advise avoiding the timing module unless you plan to pay a DJ tuner do it for you.. If you can find a PC3 or PCV (PC5) they are the way to go..
For folks just doing basic mods like exhaust, it's probably not a big deal. But if you're really into tuning and want to push beyond 15%, it sounds like you'll have to hit up a Dynojet dyno tuning center and shell out some extra cash.
Anyone have better luck with the PC6? Or is the 5 still the way to go? see its been a year now
According to dynojet, the only difference is limiting the fuel adjustment on the 6 to +15 or -15% due to EPA forcing their hand.
Although you can bring it to a dynojet shop and they will have the capability of adjusting it beyond that- they just want to make sure that it is done by someone that knows what they’re doing as opposed to your average. Joe blow setting in a manner that they shouldn’t.
Not sure why Mark had issues with his as he is obviously very capable as shown by his fleet of bikes. I have not seen others mention any issues, although I obviously haven’t looked around at other forums that I’m not involved with.
I have the five on my bike but also have a six sitting newin box. Maybe eventually I will swap them out and see what my experience would then be. I own my own dynojet dyno so can move it beyond 15% if needed but a normal bike with normal mods won’t need it.
  Bucket and cloth or low power jet wash? Davidjill_imp 15 1,329 09-21-2024, 09:14 PM
  Heads Up Kenda Cruiser K671 Yata-Garasu_imp 8 922 04-19-2024, 03:25 AM
Last Post: Ollie
  Power Wheelie! gretle_2.0 16 1,318 09-06-2023, 10:18 PM
Last Post: The Gecko_imp
  Anyone have a .drf Dynojet run file from a stock bike? PowerDubs_imp 3 394 11-08-2020, 12:38 AM
  heads up- there is a used set of SW Motech guards on EBay PowerDubs_imp 0 218 06-17-2020, 11:21 AM
  2017 More Power...? dbarkdoll_imp 16 1,118 01-24-2018, 11:01 AM
Last Post: dbarkdoll_imp
  ECU Flash - Power Delivery postoak_imp 22 1,463 09-03-2016, 05:28 AM
Last Post: dsan1964_imp
  Heads Up! - New 2014 Std in Georgetown, TX the_undecider_imp 0 186 02-05-2016, 09:59 PM
Last Post: the_undecider_imp
  Heads up on pricing for 14 DLX OldF7Guy_imp 13 883 08-23-2014, 03:18 AM
Last Post: ClassicVW_imp
