Why My CB1100EX Will Last Far Longer Than Me
We all know the engineering, manufacturing, materials, and quality control that Mitsuyoshi Kohama used to build a motorcycle "that defies logic and just demands to be ridden." All CB1100 models adhere to this guiding principle. My 2017 CB1100EX is no exception. But as I approach my motorcycle's 10-year birthday, I find myself immersed in an engineering analysis bordering on obsession. I feel a kinship with Kohama and an obligation to the next owner of my motorcycle not only to maintain it but also to ensure its future.
The core of the bike — that air-cooled inline four — is arguably one of the most durable engine architectures ever used in a motorcycle. Air-cooled engines have fewer failure points than liquid-cooled ones: no water pump to fail, no radiator to corrode, no coolant hoses to deteriorate, and no head gasket sealing coolant passages. The CB1100EX engine is under-stressed by modern standards, producing modest power from a large displacement. That's exactly the recipe for extreme longevity. Honda's metallurgy in the cylinder bores, cranks, and transmission gears is excellent, and there's nothing in that engine that can't be rebuilt or re-machined.
The steel double-cradle frame is simple, robust, and repairable. Unlike aluminum frames that are difficult to weld without specialized equipment, a steel frame can be straightened, repaired, or reinforced by any competent fabricator indefinitely.
The wire-spoke wheels on the EX are another longevity advantage — individual spokes can be replaced, rims can be re-laced, and hubs can be refurbished. All good there.
Despite having earned the highest reliability rating possible, electrical components such as the fuel injection system, ECU, sensors, wiring harness connectors, ABS module, instrument cluster, etc., pose a long-term vulnerability for my CB1100EX. When those parts fail, they simply must be replaced. Although Honda sold the CB1100 in the United States for only three years, it had a much longer run in Australia, Europe, and Japan. Parts remain available. Capacitors on circuit boards degrade whether the bike runs or not. Storing critical spares in a humidity-controlled environment is a reasonable precaution. These parts had finite production runs and do not share many components with Honda's current motorcycle line. And with the help of my friends at Webike, I have started building a spare inventory for those parts I cannot source from my local motorcycle shop. It is manageable.
Rubber and plastic components — seals, gaskets, bushings, intake boots, body panels — all have finite lifespans and must be preserved or replaced with hardened alternatives. That said, new manufacturing capabilities catering to motorcycle preservationists are making replacement options increasingly available.
By choosing air cooling, a simple steel frame, wire wheels, and a conventional layout, Kohama made a bike that's inherently more rebuildable and sustainable than most modern motorcycles. I want my motorcycle to be ridden for 100 years. With some planning and help from the great people I have engaged and this Forum, I believe that goal is possible. Many original Honda CB750s are still running today. And with all due respect to arguably the most important motorcycle ever built, the CB1100 is better engineered and is made with far better materials. Until you tell me to stop, I plan to share how I go about extending the life of my motorcycle. I am not advocating that you do the same, but I do hope you will assist me even if you find it foolish. Thanks in advance for the assist.
[Image: SgIvikX.jpeg]
2017 Honda CB1100 EX
One teeny weeny factual correction, rdprdp01: only the 2010 and 2011 models of the CB1100 came to Australia.
All the best with this long term plan.
Logistical and maintenance sustainment planning now will aid you in achieving your goal.
Time to start is while the unobtanium is still obtainable.
Regards NRTM
Copy that. Many thanks, too.
Pretty sure mine will outlast me, as long as a building doesn't fall on it.
For that matter, a building might fall on me, you never know. But, if I take care of it the way I do now and treat it like my child, it will live a long, healthy life.
(05-26-2026, 12:02 AM)Gone in 60 Wrote: Pretty sure mine will outlast me, as long as a building doesn't fall on it.
This talk of buildings that might fall...is that Caifornia speak that develops because well, you know...earthquakes? Undecided
Couldn't say it better than myself rdprdp01, I plan to keep my CB with me until I can no longer ride. Which hopefully is many many years from now. Best bike ever.
'84 Honda Magna VF700
'06 Yamaha VStar Classic 1100
'14 Honda CB1100 Std
I also plan to maintain and ride my CB1100 indefinitely. However I don't see myself stockpiling the computer parts in case they fail.  So if anything gets in my way, it will be one of those failing after the supply dries up.  Which makes me wonder, is it possible that the old CB750s will be ridden further into the future than the CB1100s?
You asked a great, interesting question, Lunchbag.
Here is what my favoriate AI engine, Claude, returned when I asked him:
What is the likelihood of a fuel injection system, ECU, sensors, wiring harness connectors, ABS module, or instrument cluster lasting 50 years on a CB1100EX that is properly maintained?
8:17 PM
That's a great longevity question — you're essentially asking whether a modern motorcycle's electronics can match the mechanical durability that made old Hondas legendary. Let me look into what's known about long-term electronic component aging.
Searched the web
This is a fascinating question because it gets at the fundamental tension of the CB1100EX — a bike designed to evoke the timeless simplicity of 1970s Hondas, but built with modern electronics that age on a very different timeline. Here's an honest, component-by-component assessment:
Fuel Injection System — Fuel injectors are intended to last for the vehicle's lifetime, typically exceeding 100,000 miles. They're precision electro-mechanical components that don't wear out on a fixed schedule but succumb to cumulative stressors — with proper care, quality fuel, and clean systems, they can perform exceptionally for decades. However, 50 years pushes well beyond what any manufacturer has designed for. The internal rubber seals and O-rings will degrade and need replacement, and deposit buildup over decades would require periodic professional cleaning. The injectors themselves could plausibly last 50 years with that care, but would almost certainly need servicing or seal replacement along the way. Verdict: possible with periodic servicing, but not without intervention.
ECU — On average, an ECU can last anywhere from 10 to 20 years, with continuous exposure to heat, vibrations, and electrical surges causing wear over time. The limiting factor at 50 years is the electrolytic capacitors on the circuit board. Electrolytic capacitors have relatively low reliability and limited lifetime, with aging mechanisms causing ESR growth and capacitance degradation over time. In older Toyota ECUs, for example, the electrolytic caps typically have a 3,000-hour rated lifespan and can be replaced by someone comfortable with a soldering iron. The good news is that this is repairable — a capacitor recap at the 20–30 year mark could extend life considerably. But an untouched ECU lasting 50 years without any degradation is extremely unlikely. Verdict: the ECU board will almost certainly need a capacitor recap, and possibly other work, well before 50 years.
Sensors (O2, TPS, coolant temp, crank position, etc.) — These vary widely. Position sensors with no moving parts (Hall effect, reluctor) can last a very long time. But oxygen sensors degrade with use and typically need replacement every 50,000–100,000 miles. Temperature sensors with thermistors can drift over decades. Over 50 years, you should expect to replace most sensors at least once, and O2 sensors several times. Verdict: multiple replacements inevitable.
Wiring Harness and Connectors — This is one of the biggest 50-year concerns. Plastic housings and rubber seals break down over time, reducing protection against environmental ingress, while vibration and mechanical stress cause connections to loosen, exacerbating corrosion. Even insulation rated for high heat can harden and crack over time. Research on road-tested automotive connectors found evidence of fretting corrosion at the contact interface on tin-plated connectors, caused by the thermal cycling that occurs in normal use. Dielectric grease and regular inspection can slow this significantly, but over 50 years the rubber boots will harden and crack, insulation will become brittle, and connectors will corrode. The copper wiring itself is fine — it's everything around it that fails. Verdict: the harness is likely the weakest link for 50-year survival. Expect connector refurbishment or partial harness replacement.
ABS Module — The ABS module combines electronics (same capacitor aging issues as the ECU) with an electro-mechanical hydraulic pump and solenoid valves. Over time, the complex electronics and connections inside the module can break down, making it less reliable and prone to failure. The most frequent issues with Honda ABS systems include loss of pressure in the braking circuit, complete lock-up of the brake pedal or pump, and programming errors. The hydraulic seals within the modulator will degrade over decades. Verdict: very unlikely to last 50 years without rebuild or replacement. Plan for at least one overhaul.
Instrument Cluster — The CB1100EX uses an analog speedometer and tach (which are durable) alongside an LCD information display. Instrument clusters deteriorate due to thermal stress, vibration, aging components, and moisture exposure. LCD polarizers degrade with UV exposure, getting darker and harder to read over years in the sun. Honda ST1300 owners, for instance, have documented their LCDs developing yellow sunspots from sunlight exposure. The analog gauges could easily make 50 years; the LCD sub-display almost certainly won't without polarizer replacement or a full LCD swap. Verdict: analog gauges yes, LCD display no — expect refurbishment needed.
The big picture: A CB1100EX's mechanical heart — the air-cooled inline-four — could absolutely run for 50 years with proper maintenance, just as 1970s CB750s are still running today. But none of the electronic systems listed above were designed with a 50-year service life in mind. With a proactive owner willing to recap ECU capacitors, replace seals, refurbish connectors, and swap degraded sensors and LCD polarizers, the bike can be kept running electronically for 50 years. But the idea of these components simply working untouched for that long, the way a set of carburetors on a 1975 CB750 might? That's not realistic. The electronics will need care that the old mechanical parts never did — and parts availability 30–40 years from now is an open question.
Hmmm...
https://speedmotoco.com/blog/mikuni-hsr-...sion-kits/
Motoloves of my life:
Heart
2014 CB1100 DX
2016 XR650L
  Fair Price for a 2017 CB1100EX? Bighonda14_imp 12 1,320 03-08-2024, 04:13 AM
Last Post: deuce17EX
  2015 CB1100EX OWNERS MANUAL omnimj_imp 3 309 10-25-2022, 10:08 PM
  My new 2017 CB1100EX. Louisiana sleeper_imp 20 1,009 05-17-2022, 09:48 AM
Last Post: sleeper_imp
  2016 CB1100EX vs 2017 CB1100EX Jfro5687_imp 20 1,206 09-07-2021, 03:22 AM
  Want to buy CB1100ex alextexan_imp 29 1,639 06-19-2021, 08:46 PM
  Can't Find a 2017 CB1100EX wishful_imp 9 556 05-10-2021, 01:30 PM
Last Post: DougsZ28_imp
  cb1100ex tank swap possible??? ricecorn_imp 1 196 04-17-2021, 06:34 AM
  2020 CB1100EX? Wheelyneat_imp 44 2,539 02-24-2021, 11:04 AM
Last Post: Yanivic_imp
  CB1100EX Test Ride Dareius_imp 40 2,236 05-08-2020, 09:04 PM
  CB1100EX for a new rider? (my daughter) tommymck_imp 79 4,415 05-16-2018, 02:04 AM
Last Post: jitaylor_imp
