Accessory Install: Handlebar Risers & Motorcycle Setup
rdprdp01 Offline
Pleasanton, CA (USA)
Threads: 196
Likes Received: 877 in 374 posts
Likes Given: 1,208
When I first purchased my CB1100EX, the motorcycle setup was absolutely perfect. I was able to ride for extended periods without any back pain, shoulder pain, or fatigue. The stock seat was comfortable. I was able to actuate the clutch, shifter, and brakes without any problems. And then the Tik-Toker incident occurred; everything changed for me.
The first thing I did when I left rehab was to mount my motorcycle. It was still comfortable, but the damage to my shoulder prevented me from extending my arm as I had done in the past. I also shrank a bit, literally losing a few inches of height. I still do not understand the physics of it, but eventually the physical therapist simply told me “You lost a couple of inches. Time to let it go because they are never coming back.” The hip and pelvis fractures also caused me to sit slightly differently on the motorcycle, too. My perfect setup was no more.
To reclaim the motorcycle, I ultimately decided I needed to raise the handlebars and pull them back slightly. I toyed with the notion of replacing the handlebars, but I decided that the cabling issues associated with a handlebar swap were too much. More importantly, I liked the stock handlebars and wanted to keep them.
I share this personal, slightly embarrassing story with you because other Members of the Forum may also be facing physical challenges like mine. Whether it is arthritis, injury, or the natural aspects of aging, our size and posture can change as we age. I hope this post may help anyone who is working through something similar or simply wants a slightly more neutral riding position than what a stock setup allows for. Handlebar risers are worthy of consideration.
As I began my research, I quickly learned that handlebar risers are not nearly as regulated as other motorcycle components. Because the handlebars and mounts are so key to handling and safety, I wanted a pair that had been certified by a credible source, were made of the finest materials, and fit the aesthetic of a CB1100. I found my risers in Germany. Here is a link:
https://www.motea-shop.com/en_us/handleb...6eN-LyXWSK
The Motea Risers were ABE Certified and capable of the performing well in a crash scenario. You can always count on the Germans for great engineering:
[Image: WOFG8dO.jpeg]
[Image: ooY6wXu.jpeg]
[Image: 10IeAfW.jpeg]
I was a little nervous installing the risers because I did not want to damage the most beautiful gas tank I have seen on any vehicle. To channel that angst, I compensated by focusing on details. Here is what I did:
Step 1: I staged the risers and assembled the tools I needed to complete the installation:
[Image: 5Drazlq.jpeg]
Step 2: I covered the gas tank with a furniture blanket:
[Image: iGEmNII.jpeg]
Step 3: I loosely secured the handlebars to the motorcycle with ROK Straps:
[Image: wuGeNzh.jpeg]
[Image: F80xCx1.jpeg]
Step 4: I removed the top portion of the stock handlebar riser:
[Image: fbOqxpW.jpeg]
Step 5: I cleaned the nasty gunk I uncovered by gentling sanding it with a 120-grit sanding block and then using rubbing alcohol to remove the residue:
[Image: p2P6Crg.jpeg]
[Image: jnqRymW.jpeg]
[Image: N2vGLBP.jpeg]
[Image: m5XV1Tz.jpeg]
Step 6: I attached the new handlebar risers. Note that the torque setting for the bolts is 23 nM (I love hearing the click of torque wrench Smile )
[Image: vwvhQDg.jpeg]
[Image: QhH18y8.jpeg]
[Image: e5LUt4K.jpeg]
[Image: NBw00Zq.jpeg]
Step 7: I checked all the cables and made sure that everything had the proper clearance. I also “turned” the handlebars far left and far right to make sure there was nothing restricting movement.
[Image: BZ0KzkK.jpeg]
Step 9: I measured from the RLETs to the floor on both sides of the handlebar to make sure everything was level:
[Image: UaiIihc.jpeg]
Step 8: My most crucial step was to reach out to an industry expert: The Ferret. I asked for guidance about the proper way to setup a motorcycle. The Ferret has set up hundreds of motorcycles and very graciously gave me the following advice. Using my iPad and some patience, I did exactly what the Ferret recommended:
“But the main thing is you can't change the relationship between the seat and the foot pegs so you change the relationship of the bars, levers, and mirrors. Starting with the bars. Put the bike on the centerstand if you can. Then loosen the four bolts that hold the handlebars on not all the way, but enough that you can move the bars. Sit on the bike and rotate the bars forward or back until they feel good to you, then tighten the bolts. Next ...  loosen the bolt that holds the clutch lever in place and rotate it down a bit. Again while sitting on the bike rotate the lever up until with straight wrist it just touches the bottom of your outstretched fingers. You don't want to cock your wrist up or down but straight (like superman flying lol) and the lever should just touch the bottom of your fingers. Tighten it down. Repeat with the brake lever. Then adjust the heads of your mirrors for a clear view. They may have to be readjusted a bit once you're off the centerstand. Everything should fall naturally into your hands when sitting on the bike, bars, and levers with straight lines from your shoulders to your fingertips. The main problem these days is the manufacturers like to pin the switches making adjustments difficult. So, there is only so much adjustment in them.”
[Image: dNJHltU.jpeg]
The combination of the new risers and The Ferret’s skill and kindness has enabled me to return to an effortlessly ride. Thank you, Ferret.
I hope this detailed install process and setup guidance will help others.
2017 Honda CB1100 EX
05-16-2025, 09:26 PM
Tev62 Offline
Threads: 33
Likes Given: 95
RE: Accessory Install: Handlebar Risers & Motorcycle Setup
Nice job, one I have considered myself as I have short arms. These would relieve a little stress on the hip joints on the CB. I was actually looking at the manufacturerers website purchasing some up and back risers for my BMW 1300 GSA and out of curiosity looked to see what they did for the CB1100. Almost all of it for the 2017EX/RS models onwards apart from some tasty levers that fit the older models too. I have used VOIGT MOTO TECHNIK before on my 2018 Triumph Tiger 1200, they are a quality product.
These examples are black but they do them in silver too.
01-20-2026, 08:03 AM
pdedse Offline
Threads: 119
Likes Given: 814
I put these on my '14 standard and they felt great. I transferred them to the my '17ex and they didn't have the same feel so I removed them. Something slightly different between the two versions. I meant to sell the risers, but never did. And now I find they actually work great, but reversed for my KLX300. So instead of moving the handlebars back, the risers move the bars forward, which on the smallish KLX was what I was looking for.
01-20-2026, 11:15 AM
rdprdp01 Offline
Threads: 196
Likes Given: 1,208
On my 2017 CB1100EX, it worked for me during the worst of the shoulder rehab. In the Spring, I plan to remove them and see how it feels. The real hero remains the Ferret, who took the time to coach me through a thoughtful setup of my motorcycle, drawing on his skills, experience, and instincts. The Ferret made a difficult time less so. Thanks again, Ferret. David
01-23-2026, 10:37 PM
LucienLeFranc Offline
Portlandish Oregon
Threads: 11
Likes Received: 90 in 42 posts
Likes Given: 97
Thanks for your research and review.
I've been riding my new to me' 14DLX for a few days now, trying to decide if being an arthritic 6'3" with 34" inseam necessitates risers, lowered footpegs, and/or a taller seat.
Saw my PT today and she said "risers, risers, risers!" so, yes, risers!
Thanks for steering me to quality product worthy of the bike.
Motoloves of my life:
Heart
2014 CB1100 DX
2016 XR650L
04-01-2026, 09:58 PM
pdedse Offline
Threads: 119
Likes Given: 814
(04-01-2026, 09:58 PM)LucienLeFranc Wrote: Thanks for your research and review.
I'm also 6'3" and 34" inseam.  I tried barbacks (up/back), but found that seat height was more important, particularly if you feel tightness at the hips with the stock seat.
04-01-2026, 11:12 PM
rdprdp01 Offline
Threads: 196
Likes Given: 1,208
I am delighted that the many contributors to this Thread could be of service to LucienLefranc. David
04-02-2026, 02:19 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Received: 1,196 in 513 posts
Likes Given: 972
Wow, those are beautiful, and thank you for detailing the installation. You certainly take care not to let anything get damaged in the process!
The instructions alone are pretty enough to warrant framing and display on your garage wall. Very interesting to consider the relationship to the foot pedals in the process to keep your bodily geometry comfortable.
If it were me... I have a feeling my OCD would make me do this. My CB had just a slight amount of key-rash on the top brackets for the handlebars. I hit them with 0000 steel wool in the direction of the original "grain" of the brushed look, reshot them with gloss clear, and they look factory-perfect again. Looks like the finish on the risers is sort of a natural shot-peened aluminum. I wonder if it could be brushed to match the original finish of the handlebar clamps?
04-02-2026, 11:40 AM
Portlandish Oregon
Threads: 11
Likes Given: 97
(04-02-2026, 11:40 AM)Gone in 60 Wrote: Wow, those are beautiful, and thank you for detailing the installation. You certainly take care not to let anything get damaged in the process!
Key- scratched ignition areas have always made me sad.
My new-to-me 14DX dash is still in pretty good shape, giving me the impression that the previous owners didnt have multiple keys on a ring with their CB ignition key.
I myself , I'll want to have my garage door key, Givi top box key, and SW Motech keys on a ring with my ignition key, so I bought this for $12:
No way for metal to touch the CB, only leather. Worse case scenario is a small spot is shinier (a bit leather polished) than the rest of the dash.
Heart
2014 CB1100 DX
2016 XR650L
04-03-2026, 12:08 AM
  Basic Maintenance: Handlebar Weight Assembly Replacement rdprdp01 4 501 07-01-2026, 07:19 PM
Last Post: HondaLou
  Accessory Install: SW-Motech Top Case rdprdp01 4 542 09-04-2025, 07:00 PM
  Accessory Install: Rear Luggage Rack rdprdp01 5 957 05-24-2025, 01:14 AM
Last Post: Wisedrum
