Trailer loading question.
I have a drop gate utility trailer that I use for the occasional trailering of my bikes. I plan on trailering my CB to Georgia later this month to get it in to postion for the NC 'rally' in May. I will probably trailer another one of my bikes back to Florida so I have something here to ride. I'm just not 'up' to riding 500 miles to Atlanta on a Saturday and then 500 miles back to Fla. on Sunday. My problem is... I don't like the angle of the drop gate. The trailer is level and the gate is not short, but the angle of accent (more importantly, the decent) is still too much. I've done it... but with lighter bikes like my KLR and my daughters SV650. I'm scared to death to do it with my Harley and a bit concerned with the CB. But I was thinking, if I had a small low ramp... a way to lift the rear of the tow vehicle by about 4-5 inches, it would effectively lower the rear of the trailer and ease the incline. I could build something like this with a few pieces of wood...
It would be 3 to 4 two by sixes or two by tens nailed together in such a way to form a ramp UP and then a ramp DOWN. And I'd put some form of 'non-slid' material in the bottom to grip the asphalt when pressure is applied.
Any thoughts? Or... perhaps you know exactly what I'm trying to do and already have a better idea?? Thanks in advance!! Thanks
My little diagram above wants to slide to the left... in theory there is also a 'ramp' on the left, like you see on the right above.
My thought is there is a lot to go wrong here and the damage will cost more than a proper trailer. Whatever you use to prop up the rear of the tow vehicle could slip, could damage the tow vehicle and it would hurt should it slip while you were loading. I also am concerned the 2 x 6 or 10s will actually break since they are designed to bear loads on edge and not flat, they are weak laying flat as in a ramp application. You likely can see plenty of Youtube misfortunes while loading bikes on 2x6s. I think you should keep the equipment and tow vehicle in their normal attitudes and have a better metal trailer ramp built or buy a new trailer with a good ramp. I personally have used the flat U-haul trailers with front motorcycle wheel chocks and they are well suited for this. I also see lightweight trailers at TSC with great ramps and they should haul a bike just fine and have places for the tie downs. I know that's not the answer you are looking for but rigging something is asking for trouble and damage to a very expensive bike.
See you in May. Beer
Is there a reason that it would not be feasible to purchase a folding ramp that was long enough to decrease the angle to the point where you'd be more comfortable? It seems to me that there are better solutions than raising the height of the tow vehicle, but maybe I'm missing something.
There are some good folding ramps at Discount Ramps website. I purchased a non-folding ramp from them last summer and it works fine. I'm able to ride the CB and the V-strom onto the trailer without drama. You can buy ramps of different widths and lengths for your needs.
I bought this http://www.discountramps.com/non-folding...MC-RMP-NF/
Thanks Redbirds... I'll take a look.
When I load my CB into my truck, I just backup to the curb, in my front yard. This drops the tailgate down to about 12 inches off the grass. I can easily sit on the bike and ride up the ramp, or roll backwards to unload. If you have a normal curb, it works great.
What do you think?
I measured out my plan for the 'lift'... 2x10's. Do you think 2 boards (4 inches high) or 3 boards (6 inches high) are needed. Per my original note, I want to lower the ramp angle on my trailer and this seems the easiest and safest way to do it.
My trailer is back in Florida so I can't 'test' it until next week. Your thoughts?
I don't know... 4 inches might be enough.
Around here we have driveway aprons, the "ramp" that's between the end of the driveway and the curb. I just back up my vehicle enough to put the end of the trailer ramp right up against the end of the driveway and I'm good to go. The rear wheels of the trailer are just low enough to almost make it a level ride into the trailer.
Can't wait to hear how you get on ride4now.
If you put your machine onto a trailer that doesn't have a level deck as you load it...you're asking for trouble.
Be better off to either use a folding ramp in addition to the gate-ramp; or find a place with a rise you can back the car/trailer up against, so the angle on the ramp isn't so steep.
If you're desperate, you could try letting the air out of the trailer tires. Knowing that the bead might come off, and you'll have a time getting the tire changed with a load on it.
  Dog Trailer! Gone in 60 2 329 12-03-2022, 12:41 PM
  Video of Trailer Loading Dynamics Stichill 17 1,274 07-15-2019, 06:33 AM
  Rally Time Motorcycle Trailer redbirds_imp 10 992 02-21-2019, 02:59 AM
