Threads: 50
I was stopping -- almost stopped -- when my engine stopped. I put in neutral and turned the ignition off and on and went inside the store I was visiting. When I came out the bike started okay but after driving 50 yards to a stop sign it stopped again and now won't restart. Any ideas?
Not a CB but a honda.
It was the kill switch. I flipped it off and back on then gently toward the off position. It doesn't have to move even a mm. before it kills the engine. So perhaps I bumped it getting it out of the garage and then vibration moved it just enough to kill the engine.
Likes Received: 566 in 257 posts
Likes Given: 741
Those kill switches get a lot of people, that and side stand switches lol. GLad it wasn't anything serious.
Likes Given: 136
Ha Ha! Glad I never did that on my ST on I95 going 75 in heavy 4th of July traffic
Oh yeah, that was fun
Threads: 26
You're not the first one to fall victim to a sensitive kill switch.
Threads: 50
It's interesting that both times it happened I was coming to a stop. Perhaps the force of my inertia on the bars moved the switch just that tiny bit required to kill the engine. (?)
Threads: 50
It turns out this is a known problem with 1800s. Some recommend using the kill switch every time you ride to prevent the sensitivity. Others recommend spraying contact cleaner in it without disassembling. Still others had theirs replaced under warranty. I'm going to start using mine.
Threads: 125
Maybe I'm weird, but I use the kill switch every time - on every bike I've ever had.
Threads: 115
(09-08-2017, 10:33 AM)PowerDubs_imp Wrote: Maybe I'm weird, but I use the kill switch every time - on every bike I've ever had.
I NEVER use the kill switch !
Threads: 8
I always use my kill switch as well.
Likes Given: 741
Never use mine, never have.always considered it an emergency kill switch if I ever fell over
